Author Topic: Avast or Avira  (Read 4263 times)
Avast or Avira
« on: July 17, 2008, 19:32 »
Howdy, well now that AVG really do seem like they are about to pull the plug on ver 7.5 and having decided I don't want ver 8.0 then it seems like a straight choice between avast or avira.  I know a couple of people use Avira, does anyone who uses Avast recommend it  :dunno:
Re: Avast or Avira
« Reply #1 on: July 17, 2008, 20:50 »
Sorry Dave, never used either myself.  You might get some idea what they are like over at Wilders.
Re: Avast or Avira
« Reply #2 on: July 17, 2008, 22:27 »
I used Avast for a while and found it to be very good.   Davy51 uses it.
Re: Avast or Avira
« Reply #3 on: July 17, 2008, 23:16 »
I use Avira.  Found it extremely fast.  Checking all files, it does a complete scan of my system in under half a hour, AVG used to take up to a hour and a half.
Re: Avast or Avira
« Reply #4 on: July 17, 2008, 23:17 »
Forgot to mention, I once tried Avast, went to work wjile it ran, and it was still scanning when I arrived home eight hours later,  Needless to say, I stopped it and uninstalled it there and then.
Re: Avast or Avira
« Reply #5 on: July 17, 2008, 23:29 »
I uninstalled Avast because it seemed to be too fast!  :dunno:
Re: Avast or Avira
« Reply #6 on: July 18, 2008, 10:35 »
Thanks guys, so Avast or Avira it is then  :)x   i'll probably try avast on one pc and avira on the other and see how things go.
Clive why did you stop using Avast if it was very good ?
Re: Avast or Avira
« Reply #7 on: July 18, 2008, 12:59 »
Everybody seemed to be recommending AVG at the time.  Avast had a very simple interface whereas AVG looked more "professional".  I've seen only good reviews for Avast though. (apart from Chorleydave of course!)
Re: Avast or Avira
« Reply #8 on: July 18, 2008, 14:14 »
I use avast
Have for years it is fast if set up right
I havent had a virus even though i surf a lot
It has a great warning system
I tried Avira but took it off after a couple days it just didnt like my computer it blocked things it shouldnt have
But I have not tried any new version of Avira
Re: Avast or Avira
« Reply #9 on: July 18, 2008, 16:41 »
plus you don't trust anything that runs too quickly.... isn't that why you use that dodgy webbrowser..
Re: Avast or Avira
« Reply #10 on: July 18, 2008, 16:42 »
Offline cavillas
Re: Avast or Avira
« Reply #11 on: July 25, 2008, 16:59 »
I find Avira very fast and thorough. I also use spybot 1.6, Spywareblaster and Comodo BoClean.  All are very good and use little resources so far I have had no infection and also do a scan with Adaware 8.
I did try Avast but it seemed to slow too many things down, I tried the latest Avg8 but it definately slows down startup with its checking engine.
I will stick to the setup I have mainly because they are all free and work well. (Skinflint that I am, ask the wife  ;D )
Re: Avast or Avira
« Reply #12 on: July 25, 2008, 17:43 »
Careful, Alf, we'll start calling you Prudence. ;)
Re: Avast or Avira
« Reply #13 on: July 25, 2008, 22:59 »
Or just Pru.  :)
Re: Avast or Avira
« Reply #14 on: July 26, 2008, 00:41 »
Whatever you call yourselves, give yourselves a pat on the back for going over this topic again!  I'd never heard of BoClean before.
