Author Topic: Adobe Photoshop Elements 6.0  (Read 1659 times)
Online Simon
« on: July 17, 2008, 23:56 »
When I launch the above, it seems to take an age to load and start up - something like 35 seconds last time, on my new PC, which isn't a slouch.  Does anyone else use Elements, do you find it slow to start, and have you any tricks to make start up faster?
Re: Adobe Photoshop Elements 6.0
« Reply #1 on: July 18, 2008, 00:42 »
I use photoshop CS3 and that takes ages loading all its extras so I expect its a similar thing Simon. If I just want to view a jpg or some other picture file and not mess around with it then I just tell it to open in something else to save time  :)
Online Simon
« Reply #2 on: July 18, 2008, 07:23 »
Thanks, Sandra.  At least I know it's not just me!  :)
« Reply #3 on: July 18, 2008, 08:41 »
Irfanview is really good for just quickly looking at an image, and has some good tools to mess around with it. If I was using windows and needed to crop something quickly or resize something then I'd use that over photoshop any day.
« Reply #4 on: July 18, 2008, 09:15 »
My Paint Shop Pro v9 also takes ages to load.  So does the Gimp since I 'upgraded' to Vista.
Online Simon
« Reply #5 on: July 18, 2008, 09:32 »
That's the thing isn't it?  I don't mind waiting for it if I'm going to do some sort of project or something, but just to, say, save a screenshot, it's a real pain.
« Reply #6 on: July 27, 2008, 18:51 »
It takes 5 seconds or less, but I'm still using version one  :blush:
Online Simon
« Reply #7 on: July 27, 2008, 19:22 »
Get with the times, Bro!   :laugh:
