Author Topic: Which Anti Static Mat/Wrisband....  (Read 3781 times)
Offline David
  • http://Wormdive_2
« on: August 03, 2008, 01:55 »
I had to put the pc repair rebuild on hold as had horrendous time with builders (ongoing) but decided to  get prepared to try and sort out my now spare defucnt machine.
I have purchased a Lindy AS wrist band but for some reason not that happy,am now thinking I should get a mat,found one on Amazon Hama which seems to have better reviews,have any of you got a brand which you prfer or know will do the job.
I have decided to try and change the motherboard on the machine and if I install a fresh OS hopeing I can save the data which I want to preserve.
As Im not sure how to make the existing one operate on my other machine I am trying to play safe.would I just install it within the case and then set the prioity of the HDs.
Anyway first things first....................any opinions on my choice of Mat. ???
Re: Which Anti Static Mat/Wrisband....
« Reply #1 on: August 03, 2008, 02:05 »
Have to admit, all I tend to do is earth myself by touching a radiator before I start tinkering inside a PC, and I haven't come a cropper yet, but maybe I've been lucky.
Would a simpler way not be to take the hard drive out and install it as a slave in a working machine, in order to recover the data?
« Reply #2 on: August 03, 2008, 02:13 »
I just use a wristband connected to a 3 pin plug with the live and neutral wires disconnected from the plug, then stick the plug in the mains socket, thats when I am being really careful  :)
Offline David
  • http://Wormdive_2
« Reply #3 on: August 03, 2008, 02:26 »
Thanks Sandra I have seen these,yet to track one down,the only ones I have seen are with crocadile clips which I dont trust for some reason,and I am trying to be careful from the start.better safe than in a bigger mess ;D
Offline David
  • http://Wormdive_2
« Reply #4 on: August 03, 2008, 02:30 »
Going to try this tomorrow Simon,will get the machine from ustairs and put into this one,will it just connect up to it internally,trying to work out in my mind.....as I could in theory be capable of changing a hard drive,but adding one at the moment is unknown,but it wont be this time tomorrow. :-X
Offline David
  • http://Wormdive_2
« Reply #5 on: August 03, 2008, 02:39 »
Only just twigged what you have said here Sandra and read on maplins before the penny dropped I had envisaged a strap with a plug attatched but can see now what you mean.... :thumbs: thanks aagain
« Reply #6 on: August 03, 2008, 12:14 »
Yes David you have the right idea now  :)
« Reply #7 on: August 03, 2008, 12:42 »
Sandra,
I have one of those plug/strap set ups, but I must admit I rarely use it. Of course women can accumulate more static than men because of the use of nylon undergarments. Have you considered going commando as an alternative  :)x
Offline David
  • http://Wormdive_2
« Reply #8 on: August 03, 2008, 13:13 »
Looks like Tony had an idea too  :laugh:
« Reply #9 on: August 04, 2008, 01:19 »
How do you know that I dont already Tony  :devil:
« Reply #10 on: August 04, 2008, 14:22 »
 :woot:
Offline David
  • http://Wormdive_2
« Reply #11 on: August 04, 2008, 14:31 »
Not very pc though is it Sandra  ;D
« Reply #12 on: August 07, 2008, 07:55 »
I just get naked before popping the side of my case.  :o:
« Last Edit: August 07, 2008, 07:57 by Reno »
Offline Camstop
« Reply #13 on: August 07, 2008, 08:11 »
Watch you don't frazzle your conductor  :nerves:
Offline David
  • http://Wormdive_2
« Reply #14 on: August 07, 2008, 09:56 »
Good job you dont work on the meat counter at Asda.
