Author Topic: office 2007  (Read 967 times)
Offline colin.h
  • New Registration
office 2007
« on: August 03, 2008, 12:53 »
can anyone help.... in office 2000 when u mail merge u only have to click 1 button but in 2007 u have to go through a whole load of buttons, is thereany way to quicken the process
Re: office 2007
« Reply #1 on: August 03, 2008, 12:57 »
hmm, I'm unsure... but I did a quick look around and found these couple of sites - not sure if they way they describe is any faster though...
http://helpdesk.ua.edu/training/word/merg07.html
http://office.microsoft.com/en-gb/word/HA100819761033.aspx?pid=CH100626281033
http://office.microsoft.com/en-gb/word/HA101091611033.aspx?pid=CH100626261033
Re: office 2007
« Reply #2 on: August 03, 2008, 13:02 »
:welcome:  Colin!
Re: office 2007
« Reply #3 on: August 03, 2008, 18:17 »
Office 2007 is yet another one of Microsoft's backward steps.  I had to reinstall Office 2000 to get my spell check to work in Outlook Express so there is no reason you can't run both versions at the same time.
Re: office 2007
« Reply #4 on: August 03, 2008, 21:05 »
I thought there was a fix for that, Clive - or was that it?  I seem to recall you mentioning it before.
Re: office 2007
« Reply #5 on: August 03, 2008, 22:47 »
That was the fix Simon!  I now have both versions installed and it's quite easy to toggle between the two of them.  2007 is overcomplicated and totally unnecessary.  It's also very buggy and they say it was brought out in a hurry and never finished because of Vista.  Mine was pre-installed on my computer but you are better off with 2003 or 2000.
Re: office 2007
« Reply #6 on: August 03, 2008, 22:58 »
I have 2003, and if it ain't broke...   ;)
Re: office 2007
« Reply #7 on: August 04, 2008, 09:10 »
Yes indeed!   :D
