Author Topic: how to uninstall.....  (Read 1934 times)
Offline Baz
« on: August 06, 2008, 21:07 »
........Memeo Autobackup.
how do I do this?  this may sound daft but there is no uninstall for it in the program list, trying from windies add/remove feature just flashes quickly, says its finished but the prog is still there.  Huh? Huh?
Re: how to uninstall.....
« Reply #1 on: August 06, 2008, 21:14 »
Is the program definitely still there, or is it just the entry in the Add / Remove Programs list?  Do you get the option to Remove from the list?
« Reply #2 on: August 07, 2008, 13:00 »
it may have left a registry entry
This program will uninstall programs much better than windows uninstallers
it will remove all traces of the program
Revo uninstaller
« Reply #3 on: August 07, 2008, 13:10 »
That name rings a bell, Dave.  It looks good, and I'm sure I've tried it before.  :)
Offline Baz
« Reply #4 on: August 07, 2008, 14:14 »
yeah its still there, still in the start/all programs list, still all folders in Explorer and still runs when opened  ??? ???
the option to remove is there as is install/repair   the normal choices, but when I select remove then next it flashes quickly and shows the 'program has been uninstalled' window (or whatever shows)
Have done a quick google and it seems that it wont uninstall  :cussing: :cussing:
will give that suggestion from Dave a try.
« Last Edit: August 07, 2008, 14:16 by Baz »
Offline Baz
« Reply #5 on: August 07, 2008, 14:33 »
well its gone :D    used Revo uninstaller. Thanks Dave  :thumbs:   seems a good prog.
it has left the folder  and some image sub folder though, unless I havent done it right.
