Author Topic: BT slams bandwidth brakes on all subscribers  (Read 2783 times)
« on: August 07, 2008, 13:20 »
BT is throttling all of its broadband customers' bandwidth at peak times, not just heavy users, according to independent monitoring data.
http://www.theregister.co.uk/2008/08/07/bt_samknows_bandwidth_throttling/
Re: BT slams bandwidth brakes on all subscribers
« Reply #1 on: August 07, 2008, 14:31 »
this is completely ridiculous -they should be told that they can't advertise their services in the manner they do.
« Reply #2 on: August 07, 2008, 15:52 »
Surely it's a breach of contract?
« Reply #3 on: August 07, 2008, 16:20 »
You can bet they would have found a way round contractual issues.
« Reply #4 on: August 07, 2008, 17:21 »
I wouldn't be so sure, Simon.  I think it's more likely that they don't expect anyone to challenge them in court.  If I was with BT, I'd certainly be down to the small claims court.
« Reply #5 on: August 07, 2008, 17:43 »
It would certainly be worth a try, but I expect one of the T&Cs states that they can change the T&Cs at any time.  That's the trick Pipex used.  :(
« Reply #6 on: August 07, 2008, 17:55 »
i expect it does say that... argh.
« Reply #7 on: August 07, 2008, 19:15 »
If it does say that, the contract would almost certainly be voidable.  I don't remember too much from my old contract law lectures, but I seem to recall that no party is entitled to use a dominant position to vary the terms of a contract so that it is fundamentally altered.  As I said, I would be down to the small claims court.
« Reply #8 on: August 07, 2008, 20:39 »
Clive can be our test case.  ;)
« Reply #9 on: August 07, 2008, 22:31 »
I will need to check my speeds during peak periods.  In recent weeks I've been getting 3.2 Mb whereas I was previously getting 4.5Mb.  15% of 3.2Mb is <500K which is probably adequate for my modest needs.  What I object to is when they throttle me back to 150K and webpages take an age to open.
« Reply #10 on: August 07, 2008, 22:43 »
What you should be objecting to is paying for a service, and not receiving it's full worth.  If you bought a Ferrari, and then found it only did 60mph, you'd be pretty miffed, yes?  Same applies.  ;)
« Reply #11 on: August 07, 2008, 23:17 »
How would I know?   ;D
« Reply #12 on: August 07, 2008, 23:19 »
Well, I suppose not, if you never go above 28mph.  ;)
« Reply #13 on: August 07, 2008, 23:21 »
I rest my case.   :hee-hee:
« Reply #14 on: August 08, 2008, 08:11 »
blatantly not true ... I've been a car with this bloke! He aims at kids too!
