Author Topic: Intel Pent Quad core Q6600 2.4 Ghz  (Read 12702 times)
Offline David
  • http://Wormdive_2
« on: August 08, 2008, 12:56 »
Im begining my shopping list for my build and almost fallen at the first fence.the Q6600 £113 having read a few reviews this looks good but the heatsink seems not to be man enough for the job.any suggestions.I dont want a fry up before I start.if as some are stating this runs a little warm should I be afraid of this bundle I really need a tried and tested surely..although this one seems to tick the boxes for me, ???
« Last Edit: August 08, 2008, 13:06 by David »
Re: Intel Pent Quad core Q6600 2.4 Ghz
« Reply #1 on: August 08, 2008, 13:16 »
Assuming you're not going to be over clocking it, David, I would have thought the heatsink to be adequate enough, or Intel would be receiving fried CPUs back by the dozen.  I have the Dual Core version, and the heat sink supplied with mine seems fine, but don't take my word for it, hang on for other opinions.
Out of curiosity, where did you read that the supplied heatsink is inadequate?
Offline David
  • http://Wormdive_2
« Reply #2 on: August 08, 2008, 13:31 »
dabs Simon.the reviews are glowing and I was tempted, ???
« Reply #3 on: August 08, 2008, 13:40 »
So, what's stopping you?  I really don't think they would ship a high quality CPU with a crap heatsink.
Offline David
  • http://Wormdive_2
« Reply #4 on: August 08, 2008, 13:42 »
Thank you Simon.......now looking at a motherboard......I wont ask what you think though :devil: (like hell he wont)  ;)
« Reply #5 on: August 08, 2008, 13:58 »
Something that doesn't break easily!  ;D
« Reply #6 on: August 08, 2008, 14:00 »
Just bear in mind, some of them don't have PS/2 mouse / keyboard connectors, just USB.
Offline gmax
« Reply #7 on: August 08, 2008, 14:07 »
Or hire someone with a gentle touch to install it! ;D
Plenty of those Q6600 CPU's over here for about $150, used but good as new.
Offline David
  • http://Wormdive_2
« Reply #8 on: August 08, 2008, 14:23 »
There would be no fun in this would there Simon  ;D
Offline David
  • http://Wormdive_2
« Reply #9 on: August 08, 2008, 14:25 »
Im working this one out,is there no adaptors which over ride this surely I would only want PS/2 mouse to set up first time (dont go confusing me Simon)  :-X
Offline David
  • http://Wormdive_2
« Reply #10 on: August 08, 2008, 14:31 »
I will tap it very gently with my hammer it will be fine  ;)
« Reply #11 on: August 08, 2008, 15:03 »
modern motherboards *should* pick up usb mice.
Offline David
  • http://Wormdive_2
« Reply #12 on: August 08, 2008, 15:07 »
P35-DS3L looking at this,I had expected (or expect to pay more to be honest) but this looks to be up to the job,(not that I have any idea what Im on about) :)x
« Reply #13 on: August 08, 2008, 16:04 »
Not sure how much you want to spend, but is this worth a look?
Asustek S775 Intel P35 PCI-E ATX
« Reply #14 on: August 08, 2008, 16:06 »
Oh, the thing with the PS/2 connectors?  Most have one for the keyboard, which is probably the most vital, as sometimes you can't, for example, get into safe mode with a USB keyboard, if it doesn't load the drivers quick enough.  I use USB for both, but have the PS/2 option, which I have never needed so far.
