Author Topic: High TV stand  (Read 20628 times)
High TV stand
« on: August 24, 2008, 18:35 »
I'm looking for a higher than usual TV stand.  It's got to be 60cm tall, with enough shelf space for five boxes, including a large AV amp, and be able to hold a 37" flat screen TV.  All the stands I have come across have been too low to fit everything into, or have been Hi-Fi stands, which are not suitable for the TV.  I also don't want it to cost more than, say, £100.  Any help appreciated!
Re: High TV stand
« Reply #1 on: August 24, 2008, 18:42 »
have you tried Ikea?
Re: High TV stand
« Reply #2 on: August 24, 2008, 18:54 »
Seems like a good DIY project Simon, especially of you can't get what you want.  DIY has never been so easy thanks to B&Q, Homebase and Wickes.
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #3 on: August 24, 2008, 19:05 »
Have you considered the option of a modern glass and brushed chrohttp://www.theplasmacentre.com/product_details.php?products_id=1175&menu=Filtered&cpgn=16me entertainment type cabinet Simon ?
« Last Edit: August 24, 2008, 19:08 by David »
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #4 on: August 24, 2008, 19:09 »
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #5 on: August 24, 2008, 19:12 »
http://www.standanddeliver.com/acatalog/Alphason_Aragon_AG54_2-100B.html
Is this the type you want Simon....give me a clue to what style and will go hunting for you  :)
Re: High TV stand
« Reply #6 on: August 24, 2008, 19:34 »
It would be a great DIY project - that was my first thought when I read this thread.  With a good straight edge, a router and a few cutters, an accurate square and a saw (to make life easier :) ) it should be well within the capabilities of most people.
Re: High TV stand
« Reply #7 on: August 24, 2008, 20:21 »
I'm not 'most people' Gill, and can barely put up a coat hook without taking half the plaster off the wall.  ;D
David, thanks for those suggestions.  This is the sort of thing I've got now, and it needs to be much the same.  The only reason I want to replace it is, it's starting to look a bit tatty.
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #8 on: August 24, 2008, 20:27 »
ok Simon will check around for you.wont post unless its in this ilk
Re: High TV stand
« Reply #9 on: August 24, 2008, 20:31 »
 :thumbs:  Though, I suspect, as Gill said, it's probably a DIY or custom job.
Re: High TV stand
« Reply #10 on: August 24, 2008, 20:41 »
It's a pity you don't live nearer to me, or I'd make one for you.  I'm sure I could do it for less than £100.  If you like, I could try to put you in touch with some other woodworkers in your area who will be able make one.
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #11 on: August 24, 2008, 20:46 »
That one looks this way. :)x
Have found plenty of glass and chrome or do you want me to check out the antique shops as well  ;D
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #12 on: August 24, 2008, 22:29 »
Has it got to be wood Simon,have found the same sort of shape,but only in glass (black) and chrome seem to have found that  corner shape does it have to be wood or cabinet type for cables etc ?
Re: High TV stand
« Reply #13 on: August 24, 2008, 23:18 »
No, it doesn't have to be wood, but I'd prefer it to be black.
Thanks Gill, may come back to you on that,  :)
Offline David
  • http://Wormdive_2
Re: High TV stand
« Reply #14 on: August 25, 2008, 13:56 »
http://www.comet.co.uk/shopcomet/product/316474/KENMARK-TV-stand-up-to-26-inches
is this style any good Simon,Im searching for you,I even woke up thinking abiout TV stands ???
Post an example of the type of thing you might like,it will narrow the field for me
« Last Edit: August 25, 2008, 14:04 by David »
