November 27, 2024, 18:48
Technical Help & Discussion
AV Lounge
High TV stand
4
5
7
Topic: High TV stand (Read 20630 times)
Re: High TV stand
Reply #30 on:
September 15, 2008, 21:02 »
Still not tall enough, Cam. I think my only option is a hi-fi stand to put some of the equipment on, and a separate regular TV stand, but then I've got to find more space.
David
Loyal Member
http://Wormdive_2
Re: High TV stand
Reply #31 on:
September 15, 2008, 21:20 »
I hav nt seen any Simon and its that corner type angle which is the hardest and most are glass which seems to narrow the choice
Re: High TV stand
Reply #32 on:
September 15, 2008, 23:03 »
Yes, it does seem a difficult thing to find, David. I can't believe I have the most equipment in the world under a TV, but it does seem as though those with more than a VCR and a DVD are rarely catered for.
David
Loyal Member
http://Wormdive_2
Re: High TV stand
Reply #33 on:
September 15, 2008, 23:29 »
Its the same here simon,mine is stylish and all that,glass and chrome but I just manage the sky box,DVD and the anything else would get too hot so your not alone,wish I could find a decent one
Re: High TV stand
Reply #34 on:
September 15, 2008, 23:38 »
I haven't even got a bloody Sky box! It's the AV amp that takes up all the room. I don't know why they have to make these things the size of a small suitcase, and weigh half a ton.
David
Loyal Member
http://Wormdive_2
Re: High TV stand
Reply #35 on:
September 16, 2008, 09:35 »
Minimalist Simon which is ok is you have sod all
Re: High TV stand
Reply #36 on:
September 25, 2008, 21:37 »
Well, I seem to have found a solution --
http://www.ikea.com/gb/en/catalog/products/70045482
David
Loyal Member
http://Wormdive_2
Re: High TV stand
Reply #37 on:
September 26, 2008, 08:47 »
I have been looking for the wrong one Simon.this looks to long ?
Glad you found one
Re: High TV stand
Reply #38 on:
September 26, 2008, 09:56 »
I think it'll be OK, as it's in a corner, David. Only thing is, I would have preferred black. Could always paint it.
David
Loyal Member
http://Wormdive_2
Re: High TV stand
Reply #39 on:
September 26, 2008, 10:23 »
Well The Stones did.......worked for them Simon
Re: High TV stand
Reply #40 on:
September 26, 2008, 10:44 »
Just ordered a Blu Ray player, as otherwise, there would have been a gap!
Re: High TV stand
Reply #41 on:
September 26, 2008, 10:46 »
A complete new set of DVDs to go with it maybe?
Re: High TV stand
Reply #42 on:
September 26, 2008, 11:18 »
Replace all 900+? Don't think so! Still got a pile on the window sill yet to watch.
David
Loyal Member
http://Wormdive_2
Re: High TV stand
Reply #43 on:
September 26, 2008, 11:25 »
Is it a man thing?I order a new desk and decide a new pc is needed to sit on it,Simon orders a TV stand to fill the hole he orders a new Blue Ray player.Rik buys a photo frame and needs a new camera........it must be a male thing...................its great logic
Re: High TV stand
Reply #44 on:
September 26, 2008, 11:30 »
Yes, and didn't your original bathroom just need a new tap washer?
4
5
7
AV Lounge
High TV stand
