Author Topic: How to highlight a particular post  (Read 5443 times)
Offline David
  • http://Wormdive_2
« on: September 01, 2008, 16:57 »
Hope I have put this in the correct area......right its a really simple one this.
How do I highlight a particular line (for example) and then be able to post it without having posted the whole issue,if this makes sense.
I note that when members do this correctly it shades blue...The only way I have found to do this is to copy then insert as image..which although sort of works must be incorrect.
Could someone point me in the right direction,its annoying (well for me)
Thanks
Re: How to highlight a particular post
« Reply #1 on: September 01, 2008, 18:20 »
Like this, do you mean, David:
Highlight the text you want to copy, hit Ctrl-C, then insert into your post between a couple of quote markers, so the above line would look like this:
Code: [Select]
[quote]How do I highlight a particular line (for example) and then be able to post it without having posted the whole issue,if this makes sense.[/quote]
Offline David
  • http://Wormdive_2
« Reply #2 on: September 01, 2008, 18:23 »
Thanks Rik..I will have a practice.....all this time and struggled away  ??? :cheers:
Offline David
  • http://Wormdive_2
« Reply #3 on: September 01, 2008, 18:26 »
Offline David
  • http://Wormdive_2
« Reply #4 on: September 01, 2008, 18:29 »
                         ..I will have a practice      highlighted one,seperated the other just need to highlight waht I have seperated......hope I dont get detention for hijacking my own thread  ;D
« Last Edit: September 01, 2008, 18:37 by David »
Offline David
  • http://Wormdive_2
« Reply #5 on: September 01, 2008, 18:44 »
« Last Edit: September 01, 2008, 18:48 by David »
Offline David
  • http://Wormdive_2
« Reply #6 on: September 01, 2008, 18:50 »
« Reply #7 on: September 01, 2008, 18:57 »
I think you've got it.  ;)
Offline Baz
« Reply #8 on: September 01, 2008, 18:58 »
I just quote the post then delete the bits I dont want
Offline David
  • http://Wormdive_2
« Reply #9 on: September 01, 2008, 18:59 »
Not quite but on the right lines  Rik  :)
Offline David
  • http://Wormdive_2
« Reply #10 on: September 01, 2008, 19:01 »
I just quote the post then _
Now Im getting the hang of it..........I think
Offline David
  • http://Wormdive_2
« Reply #11 on: September 01, 2008, 19:03 »
Lets see   :thumbs: :thumbs: :thanks: I have been trying to do this for so long  ;D
« Reply #12 on: September 01, 2008, 19:54 »
Just click on quote and the forum software does it all for you David.  Life's a peach.   ;D
Offline David
  • http://Wormdive_2
« Reply #13 on: September 01, 2008, 20:07 »
Offline David
  • http://Wormdive_2
« Reply #14 on: September 01, 2008, 20:08 »
