Author Topic: Trying out Vista  (Read 2212 times)
Trying out Vista
« on: September 07, 2008, 06:21 »
I have put together my quad with the intention of installing ubuntu, but because ubuntu had installation problems I decided I'd try vista. So I *cough* acquired a copy, and installed it. So far, aside from some setting changes like enabling the start button, disabling the uac, and funky little widget nuisance on right its run very fast and stable. It runs about as fast as xp on this machine, but it takes up about 3x the space. It does look pretty though.  :crazy:
From where I'm sitting it doesn't live up to the hype, but then again what does.
« Last Edit: September 07, 2008, 06:44 by Reno »
Re: Trying out Vista
« Reply #1 on: September 07, 2008, 08:33 »
I wonder how much space ge next version of Windows will require?   ::)
« Reply #2 on: September 07, 2008, 09:35 »
Yes, that's true, Clive.  It can only get worse, the 'prettier' they try to make it.
« Reply #3 on: September 07, 2008, 10:51 »
yep, graphics takes space.. and lots of resources.
Have you set it up to make use of the multi-processors, or does it just do it for you? I guess my question is, do you have the ability to change how it does this?
« Reply #4 on: September 07, 2008, 15:27 »
You can assign tasks specifically to each cpu in both xp and vista. The other benefit is it takes advantage of more than 3 gigs of ram. With xp installed it would only see about 2.8 gigs.
« Reply #5 on: September 07, 2008, 16:50 »
yes, but I meant does it do this automatically / efficiently / do it run OS tasks over didn't processors or is always on the same one.
« Reply #6 on: September 07, 2008, 18:20 »
I don't understand the last part of your question. Here's a screenshot of the task manager. As far as i can tell it distributes tasks over all cores. If you feel the need to limit a process to a single core there is an option. I don't really see a difference. I doubt there is a noticeable performance difference.
http://img161.imageshack.us/img161/7346/13187730cf7.jpg
« Reply #7 on: September 07, 2008, 22:10 »
you answered what I was asking - I really wondered if Vista just hammered the one node.
« Reply #8 on: September 09, 2008, 00:21 »
Well, last night the machine was running fine. Today when i got up though it had a nice healthy spyware infestation, porn icons, popups, and all. I remember hearing awhile back how someone had figured out a way to exploit the speech recognition software remotely to gain a hold on a machine. I wonder if that's what happened in my case.
« Reply #9 on: September 09, 2008, 11:54 »
yikes!
