Author Topic: Copy program  (Read 1344 times)
Offline jww41005
Copy program
« on: September 10, 2008, 13:23 »
Hello Pals,
I want to copy Cyberlink Power Producer that is on my kid's PC and put it in mine.
We haven't got the CD anymore. I think it got borrowed >:(
So far I've done a search, put everything on a pendrive and then into my PC, but I still can't get it to work.
Any ideas. Where am I going wrong?
Cheers
John
If it works, don't fix it
Re: Copy program
« Reply #1 on: September 10, 2008, 13:25 »
You cant copy an installed program as it has placed some files in a lot of different places that you wouldnt normally be able to find.
You need to install the program from a CD or from its .exe program.
Offline jww41005
Re: Copy program
« Reply #2 on: September 10, 2008, 13:27 »
OK
Thanks for the super quick reply
John
Re: Copy program
« Reply #3 on: September 10, 2008, 15:13 »
What do you use the software for, I'm sure we can find you a free alternative...
