Author Topic: Using Linux for Photography, where we stand  (Read 2242 times)
« on: September 13, 2008, 23:55 »
http://jcornuz.wordpress.com/2008/08/21/using-linux-for-photography-where-we-stand/
Graphics and photography have been Apple’s chasse gardée for years but for quite some time, MS Windows is on par with the Mac and the system of choice for photographers boils down to personal preferences more than anything else. Mac users have the exclusivity of Apple Aperture, but Photoshop and Lightroom, Adobe’s behemoths, are available on both platforms - and the CS4 64 bits version of Photoshop for Mac will be delayed due to the necessity to porting it to Cocoa. Maybe Adobe could port it to QT and offer a Linux version, but I digress…
So what about Linux then?
My goal with this entry is to brush a big picture of where Linux stands as far as photography is concerned. What are the achievements, where improvement are needed and being worked on and which pieces are still missing. I will survey what I consider the 3 main areas that an OS has to cover for serious photography work: color management, printing support and workflow.
Note that this is a summary of subjects that are covered in more detail elsewhere in this blog; I provide internal links where appropriate.
Re: Using Linux for Photography, where we stand
« Reply #1 on: September 14, 2008, 10:44 »
Quite a way to go yet, from the look of that, Sam. :(
« Reply #2 on: September 14, 2008, 15:50 »
its not too bad to be honest - but it does depend on the level of user you are - and what you do. Its very powerful for quick automated manipulations though - and to be honest it not that hard to get photoshop working...  8-)
« Reply #3 on: September 14, 2008, 15:55 »
Under an emulation package?
« Reply #4 on: September 14, 2008, 17:30 »
using Wine, which is not really an emulation package but yeah that sort of idea - you can get quite a lot of windows programs running that way - that's how I can play quite a lot of games  ;D
« Reply #5 on: September 14, 2008, 17:34 »
Does it handle colour management?
« Reply #6 on: September 14, 2008, 20:26 »
Oh no, but I expect you might be able to get around this issues...
« Reply #7 on: September 15, 2008, 10:11 »
You might, Sam, I'd just disappear under a mountain of reading material. :)
« Reply #8 on: September 15, 2008, 10:47 »
give it time...
« Reply #9 on: September 15, 2008, 10:53 »
How long have I got? :)
« Reply #10 on: September 15, 2008, 10:57 »
not long enough.  :o
« Reply #11 on: September 15, 2008, 11:47 »
I thought that might be the case.  :cry:
