Author Topic: Please help - possible virus  (Read 12561 times)
Offline Michelle
    • Techieminx
« on: October 05, 2008, 18:23 »
Hi guys,
it doesn't take me long to come back with another problem does it lol
I'll tell you what i think happened....... I was on msn - and someone sent a picture saying can i add this pic of you to my myspace, i thought thats odd, i accepted it and it was in a zip file - I didn't open the zip file cos i thought well thats odd. BUT mysuperspyware thing said change to registry to u wish to accept and i wasn't thinking and clicked yes.... i think thats what did it.
Now what is happening is the same person keeps trying to send me that picture (now deleted him lol) and non of his other friends were getting this. And Msn keeps logging off every few mins, and so does a game that i play though IE. And its all a bit slower.
So i've done all the usual scans (avg, adware,malwarebyes, ccleaner, superspyware, lol and  afewmore)  - and i was going to scan in safe mode with restore off but I couldn't find the button for safe mode, lol - i never remember - its not f8 f9 or f10 - so i thought well I'll just scan it with restore off, but its still happening......
oh something i noticed trying to get me to accept was Jupious, i did a google on it but nothing came up its in system32 any idea?
Anyway so please can u help, what should i do next, try finding safemode again?
thanks Michelle xxx
Re: Please help - possible virus
« Reply #1 on: October 05, 2008, 18:27 »
Safe mode should be from pressing f8 just after the POST sequence, Michelle.
Offline Michelle
    • Techieminx
« Reply #2 on: October 05, 2008, 18:39 »
yeah thanks i know it should be but its not on this computer, (medion) I'll look back at my other posts I might have said.... :blush:
Offline Michelle
    • Techieminx
« Reply #3 on: October 05, 2008, 18:47 »
i found the post i was remembering, but it was f8 i was doing it wrong and still am lol thanks rik  :blush: :)x
but will that do it you think, is that the next thing to try?
what about that jupious.exe, any ideas?
« Reply #4 on: October 05, 2008, 18:52 »
Michelle you might try this one
it does a good job of finding things embedded in win32
It is slow it took 8 hours for me to scan 20 gig of programs
it is free
A Squared
http://www.emsisoft.com/en/software/free/
« Reply #5 on: October 05, 2008, 19:51 »
Hi Michelle,
I saw this recommended the other day, but have never tried it:
http://www.exterminate-it.com/
Although, I would be surprised if anything was there that none of your other scans have managed to remove.
As for 'jupious', I've also drawn a blank on that one.  :(
« Last Edit: October 05, 2008, 21:01 by Simon »
« Reply #6 on: October 05, 2008, 20:47 »
I made a mistake the other day and went surfing without a firewall
I got a similar virus and it was embedded in  win32
It didnt allow my anti-virus or spybot nor any of my other tools to even see it
I finally had to use A squar and it quarenteened it
I got the recomendation from this help site
http://www.bleepingcomputer.com/forums/index.php?
Offline Michelle
    • Techieminx
« Reply #7 on: October 05, 2008, 21:14 »
ok thanks guys, i will try those, i just managed to scan it in safemode with restore off so i am hoping that did the trick on and i delete msn before that, so I'll reinstall and try that.
that jupious was in win32 did I say?
funny that there is nothing on google about it.
thanks again
« Reply #8 on: October 05, 2008, 21:39 »
You could run hijack this and post the results.
« Reply #9 on: October 06, 2008, 01:29 »
Try doing a system restore to before you opened the dodgy file. Its changed the registry so an AV scan probably wont fix it. With later PCs safe mode can be a bit harder to get into than on earlier ones due to having SATA hard drives. Pressing F8 too early uses brings up the BBS menu (boot order), you need to wait until the first screen with text has shown and gone then hit F8 straight away before the second screen has fully loaded.
Just thought, you probably cant restore now as you turned it off to do a scan in safe mode.
The best thing you can do now will be to put your XP CD in the drive and go to startr, then run and type in SFC /SCANNOW dont forget the space between the letters SFC and the /
Hopefully that will repair the file thats been damaged/removed or replaced.
« Last Edit: October 06, 2008, 01:38 by Sandra »
Offline Michelle
    • Techieminx
« Reply #10 on: October 06, 2008, 16:30 »
hmmm xp cd...... do i have one of those..... sounds like a great idea thanks sandra, I'll have to look.
I thought that was a mistake turning of system restore, i don't know why i didn't restore it first, its normally first thing i do :(
Offline Michelle
    • Techieminx
« Reply #11 on: October 06, 2008, 18:06 »
Yay i found the XP Disc it was in an unopened packet - like a recovery one, and i did what you said, all went well so fingers crossed, its sorted it out. It does seem quicker already, but that could be me hoping lol - If not i will post the hijack this I did do a scan last night but I didn't see anything staring out at me lol.
Oh and and thats exactly it with the f8 i have to wait sometime before I can press it.
Thanks again Sandra, and fingers crossed  ;D
Offline Michelle
    • Techieminx
« Reply #12 on: October 06, 2008, 19:19 »
ok :(   that didn't work.  So it made me think it  might be something else - so i searched on msn disconnecting and someone had a problem with Java, i think i downloaded an update for Java recently ? And that game i use uses Java..... just a thought.
Anyway I've been trying to post the hijack this here but it keeps going to another page about the webmaster?  :dunno:
« Reply #13 on: October 06, 2008, 20:52 »
How are you trying to post it, Michelle?  You should be able to save the scan results as a text file, then just copy and paste the text into a post.  Just try to make sure it doesn't reveal any personal details, such as IP address, etc.  :)
Offline Michelle
    • Techieminx
« Reply #14 on: October 06, 2008, 23:07 »
ogfile of HijackThis v1.99.1
Scan saved at 18:59:54, on 06/10/2008
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16705)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\LEXBCES.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\WINDOWS\system32\CTsvcCDA.exe
C:\Program Files\CA\eTrust Antivirus\InoRpc.exe
C:\Program Files\CA\eTrust Antivirus\InoRT.exe
C:\Program Files\CA\eTrust Antivirus\InoTask.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\PROGRA~1\McAfee.com\PERSON~1\MPFSERVICE.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\WINDOWS\system32\MsPMSPSv.exe
C:\PROGRA~1\COMMON~1\X10\Common\x10nets.exe
C:\Program Files\Common Files\PCSuite\Services\ServiceLayer.exe
C:\PROGRA~1\AVG\AVG8\avgscanx.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\AGRSMMSG.exe
C:\WINDOWS\system32\RunDll32.exe
C:\WINDOWS\Dit.exe
C:\WINDOWS\CNYHKey.exe
C:\PROGRA~1\CA\ETRUST~1\realmon.exe
C:\Program Files\Home Cinema\PowerCinema\PCMService.exe
C:\Program Files\Lexmark X1100 Series\lxbkbmgr.exe
C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe
C:\Program Files\Lexmark X1100 Series\lxbkbmon.exe
C:\PROGRA~1\McAfee.com\PERSON~1\MpfTray.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.EXE
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\ATI Technologies\ATI HYDRAVISION\HydraDM.exe
C:\PROGRA~1\McAfee.com\PERSON~1\MpfAgent.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\WINDOWS\system32\jupous.exe
C:\WINDOWS\system32\lexpps.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Microsoft ActiveSync\wcescomm.exe
C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe
C:\Program Files\Creative\MediaSource5\CTDetctu.exe
C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe
C:\Program Files\Creative\Sync Manager Unicode\CTSyncU.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\PROGRA~1\MICROS~4\rapimgr.exe
C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\Program Files\Creative\MediaSource5\MtdAcqu.exe
C:\PROGRA~1\COMMON~1\Nokia\MPAPI\MPAPI3s.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
C:\WINDOWS\system32\CPdeSrvU.exe
C:\Program Files\Windows Live\Messenger\usnsvc.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://g.msn.com/0SEENUS/SAOS01?FORM=TOOLBR
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://g.msn.com/0SEENUS/SAOS01?FORM=TOOLBR
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://www.lexmark.com/MD/?func=newreg&lang=0&prtr=4476001&ctry=00000809&os=5&src=1
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - (no file)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: AVG Safe Search - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL
O3 - Toolbar: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
O4 - HKLM\..\Run: [Cmaudio] RunDll32 cmicnfg.cpl,CMICtrlWnd
O4 - HKLM\..\Run: [Dit] Dit.exe
O4 - HKLM\..\Run: [ledpointer] CNYHKey.exe
O4 - HKLM\..\Run: [Realtime Monitor] C:\PROGRA~1\CA\ETRUST~1\realmon.exe -s
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [mmtask] C:\Program Files\Musicmatch\Musicmatch Jukebox\mmtask.exe
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Home Cinema\PowerCinema\PCMService.exe"
O4 - HKLM\..\Run: [Lexmark X1100 Series] "C:\Program Files\Lexmark X1100 Series\lxbkbmgr.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe"
O4 - HKLM\..\Run: [MPFExe] C:\PROGRA~1\McAfee.com\PERSON~1\MpfTray.exe
O4 - HKLM\..\Run: [evsfun] C:\WINDOWS\evsfun.exe
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [PCSuiteTrayApplication] C:\PROGRA~1\Nokia\NOKIAP~1\LAUNCH~1.EXE -startup
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe"
O4 - HKLM\..\Run: [HydraVisionDesktopManager] C:\Program Files\ATI Technologies\ATI HYDRAVISION\HydraDM.exe
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [fybo] C:\WINDOWS\system32\jupous.exe
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKLM\..\RunServices: [fybo] C:\WINDOWS\system32\jupous.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [updateMgr] C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe AcRdB7_0_5 -reboot 1
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\wcescomm.exe"
O4 - HKCU\..\Run: [SsAAD.exe] C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
O4 - HKCU\..\Run: [PcSync] C:\Program Files\Nokia\Nokia PC Suite 6\PcSync2.exe /NoDialog
O4 - HKCU\..\Run: [igndlm.exe] C:\Program Files\IGN\Download Manager\DLM.exe /windowsstart /startifwork
O4 - HKCU\..\Run: [Creative Detector U] "C:\Program Files\Creative\MediaSource5\CTDetctu.exe" /R
O4 - HKCU\..\Run: [Creative Detector] "C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe" /R
O4 - HKCU\..\Run: [CTSyncU.exe] "C:\Program Files\Creative\Sync Manager Unicode\CTSyncU.exe"
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKCU\..\Run: [MtdAcqu] "C:\Program Files\Creative\MediaSource5\MtdAcqu.exe" /s
O4 - HKCU\..\Run: [Steam] "C:\Program Files\Steam\Steam.exe" -silent
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O8 - Extra context menu item: Add to AMV Convert Tool... - C:\Program Files\MP3 Player Utilities 3.79\AMVConverter\grab.html
O8 - Extra context menu item: Add to Media Manager... - C:\Program Files\MP3 Player Utilities 3.79\MediaManager\grab.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Run IMVU - {d9288080-1baa-4bc4-9cf8-a92d743db949} - C:\Documents and Settings\Michelle\Start Menu\Programs\IMVU\Run IMVU.lnk (file missing)
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O11 - Options group: [INTERNATIONAL] International*
O14 - IERESET.INF: START_PAGE_URL=http://www.toysrus.co.uk/
O14 - IERESET.INF: MS_START_PAGE_URL=http://www.toysrus.co.uk/
O16 - DPF: {00B71CFB-6864-4346-A978-C0A14556272C} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab31267.cab
O16 - DPF: {0A5FD7C5-A45C-49FC-ADB5-9952547D5715} (Creative Software AutoUpdate) - http://www.creative.com/su/ocx/15030/CTSUEng.cab
O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5) - http://upload.facebook.com/controls/FacebookPhotoUploader5.cab
O16 - DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} (Musicnotes Viewer) - http://www.musicnotes.com/download/mnviewer.cab
O16 - DPF: {13991839-0420-11D5-BDA3-00A0C982BA51} (PDAnalyzeCtrl Class) - http://www.raxco.com/analyze/PDWeb.cab
O16 - DPF: {14B87622-7E19-4EA8-93B3-97215F77A6BC} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab31267.cab
O16 - DPF: {2917297F-F02B-4B9D-81DF-494B6333150B} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab31267.cab
O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} (FilePlanet Download Control Class) - http://www.fileplanet.com/fpdlmgr/cabs/FPDC_2.3.2.100.cab
O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} (QDiagAOLCCUpdateObj Class) - http://aolcc.aolsvc.aol.co.uk/computercheckup/qdiagcc.cab
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://gfx1.hotmail.com/mail/w2/resources/MSNPUpld.cab
O16 - DPF: {5C6698D9-7BE4-4122-8EC5-291D84DBD4A0} (Facebook Photo Uploader 4 Control) - http://upload.facebook.com/controls/FacebookPhotoUploader3.cab
O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} (UnoCtrl Class) - http://messenger.zone.msn.com/EN-GB/a-UNO1/GAME_UNO1.cab
O16 - DPF: {5F8469B4-B055-49DD-83F7-62B522420ECC} (Facebook Photo Uploader Control) - http://upload.facebook.com/controls/FacebookPhotoUploader.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.com/v5consumer/V5Controls/en/x86/client/wuweb_site.cab?1117004803140
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object) - http://download.divx.com/player/DivXBrowserPlugin.cab
O16 - DPF: {82B56B47-90DC-4F58-9A7D-D27BA46D3C0F} (MyPhotoAlbum Easy Upload Tool Combo Control) - http://michelledh4.myphotoalbum.com/ImageUploader4.cab
O16 - DPF: {88E48871-88E6-4480-9921-F1EC4EB9AB74} (FileReadCtrl Class) - http://www.raxco.com/fileaccesstimer/WebTimedRead.cab
O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
O16 - DPF: {9122D757-5A4F-4768-82C5-B4171D8556A7} (PhotoPickConvert Class) - http://appdirectory.messenger.msn.com/AppDirectory/P4Apps/PhotoSwap/PhtPkMSN.cab
O16 - DPF: {94EB57FE-2720-496C-B33F-D9353C6E23F7} (F-Secure Online Scanner 2.1) - http://support.f-secure.com/ols/fscax.cab
O16 - DPF: {A1F2F2CE-06AF-483C-9F12-D3BAA72477D6} (BatchDownloader Class) - http://appdirectory.messenger.msn.com/AppDirectory/P4Apps/PhotoSwap/DigWXMSN.cab
O16 - DPF: {A8F2B9BD-A6A0-486A-9744-18920D898429} (ScorchPlugin Class) - http://www.sibelius.com/download/software/win/ActiveXPlugin.cab
O16 - DPF: {B1E2B96C-12FE-45E2-BEF1-44A219113CDD} (SABScanProcesses Class) - http://www.superadblocker.com/activex/sabspx.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/msnmessengersetupdownloader.cab
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (ZoneIntro Class) - http://messenger.zone.msn.com/binary/ZIntro.cab32846.cab
O16 - DPF: {BDBDE413-7B1C-4C68-A8FF-C5B2B4090876} (F-Secure Online Scanner 3.3) - http://support.f-secure.com/ols/fscax.cab
O16 - DPF: {BFF1950D-B1B4-4AE8-B842-B2CCF06D9A1B} (Zylom Games Player) - http://game05.zylom.com/activex/zylomgamesplayer.cab
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
O16 - DPF: {C606BA60-AB76-48B6-96A7-2C4D5C386F70} (PreQualifier Class) - http://www.telewest.co.uk/motive/files/MotivePreQual.cab
O16 - DPF: {CD995117-98E5-4169-9920-6C12D4C0B548} (HGPlugin9USA Class) - http://gamedownload.ijjimax.com/gamedownload/dist/hgstart/HGPlugin9USA.cab
O16 - DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} -
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O16 - DPF: {DD583921-A9E9-4FBF-9266-8DC2AB5EA0AF} (HGPlugin10USA Class) - http://gamedownload.ijjimax.com/gamedownload/dist/hgstart/HGPlugin10USA.cab
O16 - DPF: {E6187999-9FEC-46A1-A20F-F4CA977D5643} (ZoneChess Object) - http://messenger.zone.msn.com/binary/Chess.cab31267.cab
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) - http://www.creative.com/su/ocx/15034/CTPID.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\WI1F86~1\MESSEN~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\WI1F86~1\MESSEN~1\MSGRAP~1.DLL
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O20 - AppInit_DLLs: avgrsstx.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O20 - Winlogon Notify: dimsntfy - %SystemRoot%\System32\dimsntfy.dll (file missing)
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: eTrust Antivirus RPC Server (InoRPC) - Computer Associates International, Inc. - C:\Program Files\CA\eTrust Antivirus\InoRpc.exe
O23 - Service: eTrust Antivirus Realtime Server (InoRT) - Computer Associates International, Inc. - C:\Program Files\CA\eTrust Antivirus\InoRT.exe
O23 - Service: eTrust Antivirus Job Server (InoTask) - Computer Associates International, Inc. - C:\Program Files\CA\eTrust Antivirus\InoTask.exe
O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINDOWS\system32\LEXBCES.EXE
O23 - Service: Macromedia Licensing Service - Unknown owner - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee Corporation - C:\PROGRA~1\McAfee.com\PERSON~1\MPFSERVICE.exe
O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe
O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\Common Files\PCSuite\Services\ServiceLayer.exe
O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe
O23 - Service: AOL Connectivity Service (uttagaad8umai) - Unknown owner - C:\WINDOWS\system32\wofyzacouz.exe
O23 - Service: X10 Device Network Service (x10nets) - X10 - C:\PROGRA~1\COMMON~1\X10\Common\x10nets.exe
