Author Topic: Help needed removing options to boot other OS's a start up.  (Read 1776 times)
right, I have a hard drive with W2K on it that in another life, at boot up gave the option of loading anyone of two W2K Primary partitions, or to carry on with a  failed W2K set up. Meaning, if I put it in a PC [I'm knocking up, out of bits]you have catch it at that loading page to highlight the one and only OS, otherwise it goes to the Windows set up page.
Now I know it's an easy problem to sort once I'm at the right file. But I need step by step instructions on how to arrive [on a W2K machine]at that file. I'm buggered if I know how to get there  ???
Online Simon
Re: Help needed removing options to boot other OS's a start up.
« Reply #1 on: October 13, 2008, 20:55 »
Would it be something like Right click My Computer > Properties > Advanced (tab) > Startup and Recovery?
« Reply #2 on: October 13, 2008, 21:03 »
That's the easy solution, unless you pick the wrong one of the two OS's options given that they were both W2K. And if you do that it wont load at all, I know I already done it  :blush: No I want to actually remove the options from the Boot.ini file, I think its that one Simon.
But thanks all the same Bro
« Reply #3 on: October 13, 2008, 22:00 »
found it....you go through notepad to get to it
Microsoft support
Online Simon
« Reply #4 on: October 13, 2008, 22:42 »
:welldone:  Sorry we didn't get there first, but with Clive, our resident tech whiz kid, away on another bloody cruise, we're struggling! :)x
« Reply #5 on: October 14, 2008, 00:04 »
No sweat Bro, I just get to lazy to find it out myself sometimes.
« Reply #6 on: October 14, 2008, 13:53 »
This step will work perfectly
IF you know which you want to use
I have used this on dual booting OS's
As long as you are carefull you can return to the original
http://pcsupport.about.com/od/termsf/p/fixmbr.htm
« Reply #7 on: October 14, 2008, 20:52 »
cheers davy51
« Reply #8 on: October 15, 2008, 03:26 »
 :rofl:    :scoot:
