November 27, 2024, 07:32
Technical Help & Discussion
CDs
Topic: CDs (Read 1920 times)
Baz
Established Member
CDs
October 14, 2008, 19:58 »
where do you buy your blank CD/DVDs from. Any good ones you use regular and which ones do you avoid. Always found Datsafe were good enough for me. Tried to get some Taiyo Yuden dye ones but cant find them as easily. Are they all they are cracked up to be do you know
TR
Re: CDs
October 14, 2008, 20:06 »
Best Dvds IMHO are "Aone" there are one or two people on ebay or Amazon doing very good deals at the moment..probably about £18 per 100 delivered?
Re: CDs
October 14, 2008, 23:25 »
I usually use Play.com. Last time I ordered, it was £14.99 for 100 Maxell CD-R, and they were doing three for two.
Re: CDs
October 15, 2008, 07:40 »
I use ukdvdr.co.uk for my needs.
CDs
