Author Topic: Amusement for the Bored  (Read 791 times)
Offline Serenity
« on: October 15, 2008, 07:11 »
Something to keep the bored ..amused  :leer:
HOW SMART IS YOUR RIGHT FOOT?
You have to try this, it is absolutely true, I guess there are some things that the brain cannot handle.
This is from an orthopedic surgeon., this will boggle your mind and you will keep you trying over and over again to see if you can outsmart your foot, but, you can't, It's preprogrammed in your brain!
1. Without anyone watching you (they will think you are mad)  and while sitting at your desk in front of your computer, lift yourright foot off the floor and make clockwise circles.
2. Now, while doing this, draw the number '6' in the air with your right hand, your foot will change direction.
told ya! And there's nothing you can do about it!  :P
Re: Amusement for the Bored
« Reply #1 on: October 15, 2008, 07:58 »
 :bawl:  It works!
Offline Camstop
« Reply #2 on: October 15, 2008, 08:27 »
I must be ambidextrous coz i can do it even if i do look like this >  :crazy:
 :)x
« Reply #3 on: October 15, 2008, 13:19 »
ooooooooo that hard  :bawl: :crazy: :ack:
Offline Baz
« Reply #4 on: October 15, 2008, 14:45 »
good one that ;D ;D ;D ;D
but it is possible to do it :o:
« Reply #5 on: October 15, 2008, 14:55 »
And it doesn't matter what hand you use either.  :laugh:
How?
