Author Topic: Remote items  (Read 6148 times)
Offline jww41005
Remote items
« on: October 31, 2008, 12:14 »
Hello pals,
I'm thinking about moving my PC.
It'll be about 10 yards from the router, on the other side of a wall. My first question is; do wifi cards usually work well under these circumstances?
I'm also thinking about getting a remote keyboard and mouse. These will be resonably close to the PC. Apart from having to change the batteries from time to time I imagine that I won't have any problems with these.
The monitor will still have a cable connection. Any remote monitors out there, apart from my wife.... :rofl:
John
If it works, don't fix it
Re: Remote items
« Reply #1 on: October 31, 2008, 14:35 »
Hi John,
Wireless networking should work all round a house, so there shouldn't be any problem with it 'seeing' through walls.
Personally, I've never seen the point of wireless mice and keyboards, as you can't take them away from the screen.  The only advantage I can see, is one of tidiness, or perhaps if your computer is wired up to your TV.
On the subject of wireless monitors, I don't think they are here just yet, but may not be on the too distant horizon.  Wouldn't like to guess on the price of them though!
Re: Remote items
« Reply #2 on: October 31, 2008, 15:38 »
does depend on the material in the wall too... generally houses are fine though.
Offline jww41005
Re: Remote items
« Reply #3 on: October 31, 2008, 16:36 »
Thanks fellas
The wall is an interior wall which is about 30/35 years old, so it's quite thin with no sort of insulation.
The actual PC is going to be in a cupboard (well ventilated) with the monitor and power cable running out the back. I'll be able to use the monitor on a nearby table with the cordless/remote keyboard and mouse.
Anyway, I'll put a wifi card in first and move the PC to the other room and see what happens before I splash out on a monitor.
I'll post what happens
Cheers :thumbs:
Offline jww41005
Re: Remote items
« Reply #4 on: November 04, 2008, 17:55 »
Did it!
I had to reset the router because it wouldn't talk to my wifi card. The card was picking up signals from two other sources apart from my own.
Working fine....
John
Re: Remote items
« Reply #5 on: November 04, 2008, 18:11 »
Just checking, have you secured the wireless connection, John?
Offline jww41005
Re: Remote items
« Reply #6 on: November 05, 2008, 09:37 »
Hello Simon,
Well, the Windows firewall is activated, and I also have Norton Intenet Security 2008, up-to-date.
I have read a bit about changing the access password after establishing the initial setup, but I'm not too sure how to do that. I hate playing with the configuration etc. The setup was done with a CD Rom from the provider, which, to put it mildly, doesn't do what it is supposed to do very well.
Anyway, I assume that this isn't enough, so please tell what else I could do.
Cheers
John
Re: Remote items
« Reply #7 on: November 05, 2008, 11:33 »
Ideally, you should change the access password, and SSID of the router, and use WPA security, with a 63 character passkey.
I may not be able to tell you how to do it, but if you let us know what router you have, I expect Rik, or someone else, would be able to help.
Offline jww41005
Re: Remote items
« Reply #8 on: November 05, 2008, 18:07 »
Thanks Simon,
I'll get back to you on this in a day or two.
Cheers
Offline jww41005
Re: Remote items
« Reply #9 on: November 10, 2008, 10:48 »
Ok, I've got some free time.
Change SSID....
I have what is called an 'ADSL Kit', which came with the server install CD Rom. Everything was done automatically, more or less.  The router is a 'Telefonica zyxel'.
I've had a look around the internet connections configuration, but I can't find anything regarding the password. The connection is done as soon as I boot up the PC.
Any step by step help for a dummy?
Cheers
Re: Remote items
« Reply #10 on: November 10, 2008, 11:38 »
I'm not familiar with that router, John, so hopefully Rik, or someone else, will be along soon.
Re: Remote items
« Reply #11 on: November 10, 2008, 11:42 »
Me neither. :(
Re: Remote items
« Reply #12 on: November 10, 2008, 11:48 »
Any useful links, Rik?  :dunno:
Re: Remote items
« Reply #13 on: November 10, 2008, 15:10 »
Not really. Kitz doesn't list the Zyxel and I'm guessing it's a Spanish model, so the best I can offer is their site:
http://www.zyxel.es/web/index.php
Offline jww41005
Re: Remote items
« Reply #14 on: November 10, 2008, 19:18 »
Thanks fellas
Yeah, it's Spanish.
I'm working on it.
Let you know what happens
Cheers
