Author Topic: Folder Passwords  (Read 2139 times)
Offline Michelle
    • Techieminx
Folder Passwords
« on: November 04, 2008, 18:31 »
Hi all,
I wonder if you know how I can put passwords on folders on XP that are on a memory key ?
Do I need to get a special programme?  I don't understand why this wouldn't be available on XP already?
All I can find on the subject is about this "private folder" from microsoft but its not guaranteed by microsoft? And even then I'm not sure if it will work on a memory key that is being used on different pc's and laptops?  :-\
Any ideas guys please ?
Thanks
Offline Camstop
Re: Folder Passwords
« Reply #1 on: November 04, 2008, 19:15 »
Hi Shell
Can't you right click on the folder, Properties then set who can view it in the security tab  ':|
Unless i'm misunderstanding the question which wouldn't be a first  :)x
« Reply #2 on: November 04, 2008, 21:13 »
Hi Michelle,
I think you can only password protect zipped folders, so first, right click the folder you want to protect, then Send To > Compressed (zipped) Folder.  Then you need to click on the now zipped folder, but don't Extract, click File > Add a password.  It should be fairly straightforward from then on.
Of course, this will then leave the original unzipped folder unprotected, so you can either delete that, or move it to a separate back up directory.  :)
Offline Michelle
    • Techieminx
« Reply #3 on: November 04, 2008, 21:29 »
you can do that on a shared network Cammy but I want this for work on a memory key.
I did read that you could do that Simon but I was hoping there was a way to just do it to normal folders, although I guess it won't make much difference to zip it - but then I will I have to make sure the PC or laptop being used has winzip or suck like to open it?
Or if anyone has another way, please let me know thanks.
« Reply #4 on: November 04, 2008, 21:41 »
I've never heard of suck like  ;D  but any Windows XP (or later, or possibly even earlier) machine will be able to unzip a folder, as the facility is built in.  It's only when you start using .rar files, and the like, that you need something special to open them.  :)
« Reply #5 on: November 05, 2008, 00:35 »
I though that most USB flash drives have an option to password protect the whole drive, have you checked the makers site ?
« Reply #6 on: November 05, 2008, 03:47 »
Have a look here Michelle for how to do it :
http://www.nick-james.com/public/684.cfm
Free program available to download from here :
http://www.truecrypt.org/downloads.php
Offline Michelle
    • Techieminx
« Reply #7 on: November 05, 2008, 07:53 »
oh thanks sandra I'll look at that, there's an idea.  ;D
« Reply #8 on: November 05, 2008, 10:46 »
Truecrypt is excellent, Michelle.
