Author Topic: PC Anywhere  (Read 2317 times)
Offline Gemini
PC Anywhere
« on: March 26, 2003, 18:34 »
Has anyone had any experience or knowledge of using PC Anywhere by Symantec?  I just had a brainwave today (I do so occasionally ;)) and thought it might be useful for my home machine to access my office machine.  Means I'll have to be there even less  ;D
url=http://pc-pals.com/userpics/gemsig2.swf]Flash[/url]
Re:PC Anywhere
« Reply #1 on: March 26, 2003, 18:44 »
I used pcAnywhere quite a bit until Windows 2000 and XP came along with Terminal Server/Remote Desktop 8)
What do you need to know Gemini ?
Offline Gemini
Re:PC Anywhere
« Reply #2 on: March 26, 2003, 18:51 »
Oh you've thrown me now Adept, I heard that Remote desktop wasn't as secure or as good as using PC Anywhere and up till now I hadn't really bothered.  It was just the thought of being busier workwise these days that I could limit some of my travelling.  Is Remote Desktop easy to set up and use?
Re:PC Anywhere
« Reply #3 on: March 26, 2003, 19:21 »
Remote Desktop is as secure as any Microsoft product Gemini. Just keep up with the security patches ;)
Actually, you shouldn't actually remote desktop directly onto your PC. It's better to set up a Virtual Private Network and use that to run Remote Desktop. Is that a little too complicated for you? ;)
As for Remote Desktop being as good as pcAnywhere; I would say the RD is much faster :)
Offline Gemini
Re:PC Anywhere
« Reply #4 on: March 26, 2003, 19:24 »
Ahhh now you're getting complicated Adept  ;)  I was thinking of something simple just to access the work machine :)  Anything too complicated would be easier just to drive to the office  8)
Re:PC Anywhere
« Reply #5 on: March 26, 2003, 19:31 »
The other aspect to remember is that pcAnywhere works with an ordinary modem, whereas Remote Desktop really needs a fast Internet connection such as ISDN/ADSL. It also helps to have an "always on" connection to the Net.
Maybe pcAnywhere is better for your needs Gem :)
Offline Gemini
Re:PC Anywhere
« Reply #6 on: March 26, 2003, 19:34 »
You're quite right Adept, no chance of a faster modem here, I'll have to stick to pc anywhere anyway.  I joined a local pressure group for broadband in the dales, hope I don't have to go on marches and things lol.
Re:PC Anywhere
« Reply #7 on: March 26, 2003, 19:46 »
You'll be chaining yourself to telephone exchanges before you know it Gem ;) ;D
Offline Gemini
Re:PC Anywhere
« Reply #8 on: March 26, 2003, 19:52 »
Lol adept I doubt it, but I'll let you know if I do and you can see me on the news being cut free and arrested  ;)
