Author Topic: Male or Female?  (Read 696 times)
Offline Serenity
Male or Female?
« on: November 08, 2008, 21:31 »
FREEZER BAGS: They are male, because they hold everything in, but you can see right through them
PHOTOCOPIERS: These are female, because once turned off; it takes a while to warm them up again. They are an effective reproductive device if the right buttons are pushed, but can also wreak havoc if you push the wrong Buttons.
TYRES: Tyres are male, because they go bald easily and are often over inflated
HOT AIR BALLOONS: Also a male object, because to get them to go anywhere, you have to light a fire under their butt  ;D
SPONGES: These are female, because they are soft, squeezable and retain water.
WEB PAGES: Female, because they're constantly being looked at and frequently getting hit on.
TRAINS: Definitely male, because they always use the same old lines for picking up people.
EGG TIMERS: Egg timers are female because, over time, all the weight shifts to the bottom
HAMMERS: Male, because in the last 5000 years, they've hardly changed at all, and are occasionally handy to have around.
THE REMOTE CONTROL: Female. Ha! You probably thought it would be male, but consider this: It easily gives a man pleasure, he'd be lost without it, and while he doesn't always know which buttons to push, he just keeps trying  :)x
Online Simon
Re: Male or Female?
« Reply #1 on: November 08, 2008, 22:49 »
:clever:  ;D
Offline Camstop
Re: Male or Female?
« Reply #2 on: November 08, 2008, 22:55 »
 :goodpost:
Re: Male or Female?
« Reply #3 on: November 17, 2008, 13:17 »
 :clever: :clap:  :thumbs:
