Author Topic: After a new tv  (Read 6340 times)
Offline mrapoc
    • Overclock3d.net Forums and Review site
After a new tv
« on: November 09, 2008, 19:52 »
Hello again all
As posted on Idnetters:
Im after a nice 1080p flat screen in my room for use with my PS3. I also want a go at freesat and possibly hook it up to sky from the box downstairs.
I could get one of those panasonic offerings with freesat onboard but this does increase in price...perhaps spend less on perhaps what could have a better picture and get a dedicated/standalone freesat box which may also perform better?
The better picture i can get for cheaper the better (sub £1000 at the very least)
cheers!
Intel e6300 @ 2.8ghz 1.4v
Asus P5b deluxe
OCZ Reaperx 4gb PC2-8000
OCZ Gamextreme 600w
2x 320gb Seagate 7200.10
EVGA nVidia 8800gt 512mb
Re: After a new tv
« Reply #1 on: November 09, 2008, 20:29 »
A Freesat box would enable recording, Sam, currently to a second recording device, but Freesat boxes with record facilities are about to appear.
Have you decided whether you'd prefer LCD or Plasma?
Re: After a new tv
« Reply #2 on: November 09, 2008, 20:35 »
You might also want to check out this thread, Sam, as Clive is also in the market for something new.  You could compare notes!  ;)
Offline mrapoc
Re: After a new tv
« Reply #3 on: November 09, 2008, 20:36 »
No idea tbh mate  ???
It would primarily be for gaming on my ps3...movies off my ps3...and freesat (which i can always purchase at a later date once recording ones come out or w/e)
My room isnt exactly bright..or large
Just dont want to risk burning a nice image into my £500 - £1000 tv lol  :o
Asus P5b deluxe
OCZ Gamextreme 600w
Re: After a new tv
« Reply #4 on: November 09, 2008, 20:41 »
LCDs are less prone to screen burn, but you may find, certainly with the cheaper ones, you can notice motion blurring, especially with games.
Offline mrapoc
Re: After a new tv
« Reply #5 on: November 09, 2008, 20:57 »
Will a £700 lcd tv be considered "cheap" ?
1 thing i wouldnt be able to stand in a tv is
Gradient banding! drives me nuts
Blurring is a bit annoying too
Asus P5b deluxe
OCZ Gamextreme 600w
Re: After a new tv
« Reply #6 on: November 09, 2008, 21:22 »
No, £700 should get you something very nice, if you shop around.  You won't go far wrong with a Sony (LCD), or a Panasonic (Plasma).  If it's a smallish room, I wouldn't go for anything much bigger than a 32", especially if you're sitting up close to it.  That way, you should still get a good picture quality, but I can't comment on gaming on one, as I've never tried it.  I do know that a tennis game on one I saw in a shop, looked incredibly realistic, and it took me a while to actually realise it wasn't a real match!
Offline mrapoc
Re: After a new tv
« Reply #7 on: November 10, 2008, 18:17 »
Id be sat about..........2.5m - 3m away
Asus P5b deluxe
OCZ Gamextreme 600w
Re: After a new tv
« Reply #8 on: November 10, 2008, 18:31 »
That's about where I am from mine, which is a 37 inch plasma.  I don't think you'd want much bigger for that viewing distance.
Re: After a new tv
« Reply #9 on: November 10, 2008, 18:35 »
Which way would you go for Sam's use, Simon, plasma or LCD?
Offline mrapoc
Re: After a new tv
« Reply #10 on: November 10, 2008, 21:46 »
Iv just done a bit of reading on the matter (shock horror!) and plasma doesnt seem as bad as it was (anti burn in, less ghosting) but it still is succeptible especially with those games with HUDs (heads up display) around the side. Almost like a element of the game in the same position for about 80% of the time. I sir would not like to take this risk. It is also succeptible to such things as ... erm ... when there is a lot of bright light.. i.e explosions... it can almost make the pixels stick like a ghostly mist temporarily..this would be annoying as to remedy it you would need to watch normal tv/do something else/turn it off  :laugh:
LCD seems the way to go..in my underexperienced eyes
Sony bravia looks sweet..but is it overpriced like most sonys?
Obviously then i will not have the built in freesat which the panasonic plasmas do have...how much am i looking at for a decent HD box? I may take advantage of sky multiroom but the lack of HD would sadden me  :cry:
thanks
much loveness  :stupid:
Asus P5b deluxe
OCZ Gamextreme 600w
Re: After a new tv
« Reply #11 on: November 10, 2008, 23:51 »
It's difficult to say, Rik, as I don't play games on mine, so I can't really advise as to which is best on that front.
The points Sam made about screen burn and stuck pixels with plasmas is a valid one, but I think today's models are probably pretty immune to such catastrophes.  The best thing is to turn down the contrast while playing games.  If you're in a fairly dark room, you'll still get good picture quality.
With LCDs, the risks of screen damage are less, but you have to consider the possibility of motion blur, although again, modern panels will probably have more or less overcome this.
Sam, my advice would be to dig around on AVForums, and then go and look at some panels in action in the shops.  Ask if they can plug a game in, and see what the quality is like, on both LCD and plasma.  Don't forget, under shop lighting, the picture on a plasma may look slightly 'dull', compared to the LCD, but when you get it home, that won't be an issue.
Oh, and if you go for a Bravia, a Freesat box will currently set you back about £150 for the HD version, and about £299 for a recordable one, but I'm sure they will soon come down in price.
Offline mrapoc
Re: After a new tv
« Reply #12 on: November 13, 2008, 17:40 »
Anyone has experience of the Sony "KDL40W4000" ?
Supposed to be good for gaming, IDK if i saw it myself in the sony centre today but it seems one to look out for.
Asus P5b deluxe
OCZ Gamextreme 600w
Re: After a new tv
« Reply #13 on: November 13, 2008, 18:10 »
I think all of the Sony Bravia range have a good reputation, but do a search for the model number on AVForums.  I'll try to find some reviews for you later, when I'm back on the computer.
Offline mrapoc
Re: After a new tv
« Reply #14 on: November 13, 2008, 20:11 »
Ok thanks mate
I can get it for as little as £750 (hmm still quite a bit)
Is it worth getting these extended warranty? Whats the likelyhood it will die?
Asus P5b deluxe
OCZ Gamextreme 600w
