Author Topic: Mountains and molehills  (Read 1199 times)
« on: November 12, 2008, 13:00 »
http://www.realclimate.org/index.php/archives/2008/11/mountains-and-molehills/
As many people will have read there was a glitch in the surface temperature record reporting for October. For many Russian stations (and some others), September temperatures were apparently copied over into October, giving an erroneous positive anomaly. The error appears to have been made somewhere between the reporting by the National Weather Services and NOAA's collation of the GHCN database. GISS, which produces one of the more visible analyses of this raw data, processed the input data as normal and ended up with an October anomaly that was too high. That analysis has now been pulled (in under 24 hours) while they await a correction of input data from NOAA.
There were 90 stations for which October numbers equalled September numbers in the corrupted GHCN file for 2008 (out of 908). This compares with an average of about 16 stations each year in the last decade (some earlier years have bigger counts, but none as big as this month, and are much less as a percentage of stations). These other cases seem to be mostly legitimate tropical stations where there isn't much of a seasonal cycle. That makes it a little tricky to automatically scan for this problem, but putting in a check for the total number or percentage is probably sensible going forward.
It's clearly true that the more eyes there are looking, the faster errors get noticed and fixed. The cottage industry that has sprung up to examine the daily sea ice numbers or the monthly analyses of surface and satellite temperatures, has certainly increased the number of eyes and that is generally for the good. Whether it's a discovery of an odd shift in the annual cycle in the UAH MSU-LT data, or this flub in the GHCN data, or the USHCN/GHCN merge issue last year, the extra attention has led to improvements in many products. Nothing of any consequence has changed in terms of our understanding of climate change, but a few more i's have been dotted and t's crossed.
But unlike in other fields of citizen-science (astronomy or phenology spring to mind), the motivation for the temperature observers is heavily weighted towards wanting to find something wrong. As we discussed last year, there is a strong yearning among some to want to wake up tomorrow and find that the globe hasn't been warming, that the sea ice hasn't melted, that the glaciers have not receded and that indeed, CO2 is not a greenhouse gas. Thus when mistakes occur (and with science being a human endeavour, they always will) the exuberance of the response can be breathtaking - and quite telling.
A few examples from the comments at Watt's blog will suffice to give you a flavour of the conspiratorial thinking: "I believe they had two sets of data: One would be released if Republicans won, and another if Democrats won.", "could this be a sneaky way to set up the BO presidency with an urgent need to regulate CO2?", "There are a great many of us who will under no circumstance allow the oppression of government rule to pervade over our freedom—-PERIOD!!!!!!" (exclamation marks reduced enormously), "these people are blinded by their own bias", "this sort of scientific fraud", "Climate science on the warmer side has degenerated to competitive lying", etc… (To be fair, there were people who made sensible comments as well).
The amount of simply made up stuff is also impressive - the GISS press release declaring the October the 'warmest ever'? Imaginary (GISS only puts out press releases on the temperature analysis at the end of the year). The headlines trumpeting this result? Non-existent. One clearly sees the relief that finally the grand conspiracy has been rumbled, that the mainstream media will get it's comeuppance, and that surely now, the powers that be will listen to those voices that had been crying in the wilderness.
Alas! none of this will come to pass. In this case, someone's programming error will be fixed and nothing will change except for the reporting of a single month's anomaly. No heads will roll, no congressional investigations will be launched, no politicians (with one possible exception) will take note. This will undoubtedly be disappointing to many, but they should comfort themselves with the thought that the chances of this error happening again has now been diminished. Which is good, right?
In contrast to this molehill, there is an excellent story about how the scientific community really deals with serious mismatches between theory, models and data. That piece concerns the 'ocean cooling' story that was all the rage a year or two ago. An initial analysis of a new data source (the Argo float network) had revealed a dramatic short term cooling of the oceans over only 3 years. The problem was that this didn't match the sea level data, nor theoretical expectations. Nonetheless, the paper was published (somewhat undermining claims that the peer-review system is irretrievably biased) to great acclaim in sections of the blogosphere, and to more muted puzzlement elsewhere. With the community's attention focused on this issue, it wasn't however long before problems turned up in the Argo floats themselves, but also in some of the other measurement devices - particularly XBTs. It took a couple of years for these things to fully work themselves out, but the most recent analyses show far fewer of the artifacts that had plagued the ocean heat content analyses in the past. A classic example in fact, of science moving forward on the back of apparent mismatches. Unfortunately, the resolution ended up favoring the models over the initial data reports, and so the whole story is horribly disappointing to some.
Which brings me to my last point, the role of models. It is clear that many of the temperature watchers are doing so in order to show that the IPCC-class models are wrong in their projections. However, the direct approach of downloading those models, running them and looking for flaws is clearly either too onerous or too boring. Even downloading the output (from here or here) is eschewed in favour of firing off Freedom of Information Act requests for data already publicly available - very odd. For another example, despite a few comments about the lack of sufficient comments in the GISS ModelE code (a complaint I also often make), I am unaware of anyone actually independently finding any errors in the publicly available Feb 2004 version (and I know there are a few). Instead, the anti-model crowd focuses on the minor issues that crop up every now and again in real-time data processing hoping that, by proxy, they'll find a problem with the models.
I say good luck to them. They'll need it.
Re: Mountains and molehills
« Reply #1 on: November 12, 2008, 16:52 »
 :haha:  Excellent story Sam.  September's data.   ;D  ;D  ;D
