Author Topic: Reinstalling XP sp2 on SATA drive  (Read 1877 times)
« on: November 14, 2008, 13:50 »
Howdy folks  ;)
As per title I want to start afresh on my PC rather than do a factory restore ie get rid of all the rubbish.  As things stand at the moment the SATA drives are seen as IDE. When I wipe the drive and start afresh will the SATA drives be recognised by the XP sp2 disc (3 1/2 yrs old). I don't want to be prompted for SATA drivers as the machine has no floppy drive. I did read something about disabling AHCI in the bios to achieve this  :dunno:
Re: Reinstalling XP sp2 on SATA drive
« Reply #1 on: November 14, 2008, 14:36 »
Which PC are you doing it on Dave, it was only the earlier sata enabled mobo and bios that needed the drivers, later ones are fine.
« Reply #2 on: November 14, 2008, 15:31 »
I knew this would be up your street Sandra.  :) I'm doing it on an oldish medion pc - bought April 2005. The 8386 to be exact. MSI mobo same as the 8383 but can't off hand remember the model. I thought that if drivers were needed they would be loaded when you do a factory restore but it could be a problem if doing a clean install from the windows disc.
Edit...just remembered, its the MSI 7091 v.2
« Last Edit: November 14, 2008, 15:34 by daveeb »
« Reply #3 on: November 14, 2008, 17:08 »
I think you should be ok at that Dave.
« Reply #4 on: November 14, 2008, 22:29 »
Thanks Sandra. Your a gem  ;)
