Author Topic: Scientific Picture of the Week  (Read 1844 times)
« on: November 16, 2008, 09:49 »
First Direct Detection of an Exoplanet
It pains me to say this in a way, since I’ve spent the last couple of years trying todo the same thing (but at radio wavelengths) but the first extrasolar planet (i.e. a planet orbiting around a star which is not the Sun) appears to have been directly detected. Oh and its not just one… there are a couple! The first (image above) was discovered using the Hubble Space Telescope imaging the star Fomalhaut which is located about 25 light years from Earth. For a number of years there has been evidence of a planet being present - due to the perturbations it caused on the ring of gas and dust that surround the star. The planet is believed to have a mass similar to that of Jupiter but is at an orbital radius much further away (about 4 times that of the distance between Neptune and Jupiter).
Re: Scientific Picture of the Week
« Reply #1 on: November 16, 2008, 09:49 »
« Reply #2 on: November 16, 2008, 11:07 »
Oh Haley sends her commiserations and regards.  She reckons exoplanet research is the most difficult field in astronomy.
« Reply #3 on: November 16, 2008, 12:11 »
I'm sure your time will come, Sam.  :)
« Reply #4 on: November 16, 2008, 12:53 »
probably one of the hardest... which is why I also do the radio survey stuff... gotta keep myself broad - yes obivous joke there.
« Reply #5 on: November 16, 2008, 13:02 »
Now you need to write a definition of obivous, Sam. ;)
