Author Topic: How Do I Rotate MPG Files ?  (Read 1894 times)
Offline DJ
« on: March 29, 2003, 19:44 »
Hi All,
Hope your all well ;D
I have just taken some mpg videos with my new Sony DSC-U10 digital camera.
problem is I held the camera in portrait mode and now when I play the files back on my PC, they are rotated (The camera records in landscape - if you know what i mean!)
So is there anyway (without tilting my head to the left) to rotate these mpg video files the right way up?
A piece of freeware would be ideal - sadly I can't find anything.
Once again - thanks for your help.
DJ1UK
Re:How Do I Rotate MPG Files ?
« Reply #1 on: March 29, 2003, 20:19 »
I dont know for certain that it will do it but Pinnacle Studio 8 is supposed to be one of the best progs around for editing and doing things with video cams,its not cheap though unless you know where to shop  ;)
A description of the prog is available here :
http://www.pinnaclesys.com/ProductPage.asp?Product_ID=577&Langue_ID=2
Offline DJ
« Reply #2 on: March 29, 2003, 21:20 »
Think i'm on to something with a little freeware program called Virtual Dub. I'll give it a try and get back to you...
EDIT: Yep sorted it.
Used freeware from virtualdub.org and vidiopak from stoik.com
Offline bat69
« Reply #3 on: March 30, 2003, 09:44 »
Thanks for the information DJ1UK ... it could prove very useful to others with cams :)
