Author Topic: pc wont boot after installing belkin adapter  (Read 996 times)
Offline beverley
  • New Registration
« on: February 07, 2009, 22:06 »
got this e machines 540 installed belkin wireless adapter then kept freezing mouse message come up recovered after serious error and then when restarted just showing screen e machines wont go further even with recovery disc please help
Re: pc wont boot after installing belkin adapter
« Reply #1 on: February 07, 2009, 22:26 »
firstly is the belkin wireless adapter a usb one? Is it still attached?
Did the mouse start freezing after you first installed it, or after a reboot?
Could you give us more specifics, i.e. the operating system you are using
Offline Camstop
« Reply #2 on: February 07, 2009, 22:27 »
Hi Bev and  :welcome:
I can't help you with this problem but hopefully someone will soon or overnight.
Online Simon
« Reply #3 on: February 08, 2009, 00:29 »
Hi Bev, and  :welcome:
As Sam said, we could do with a few more details, i.e. is this on Vista or XP, and if Vista, is the Belkin adapter Vista compatible?
If USB, have you removed the adapter before trying to start the machine?
Can you start the machine in safe mode (usually, press F8 at the first boot screen)?  If so, you could try uninstalling the Belkin adapter, and see if it brings things back to normal.
