Author Topic: Read ahead caching (turn off?)  (Read 1653 times)
Offline Andy K
« on: February 15, 2009, 12:07 »
:bawl:
When you select a group of files in explorer in vista (and XP I think) it automatically starts trying to read them into cache just incase you want to copy them.
This is just about ok if they are local small files, but I really p***ing me off now, as I am trying to copy 500GB from a CDRW (which doesn't seam to be very fast).
As soon as I even select them it's processing away and eventually crashes.
Would love to turn this feature off (although may not fix this problem)
can you ? any idea's how ?
Thanks.
P.S - I am so feed up with Windows that I should consider an alternative O/S
Re: Read ahead caching (turn off?)
« Reply #1 on: February 15, 2009, 12:14 »
Afaik, Andy, there's no caching setting for an optical drive, only HDs.
« Reply #2 on: February 15, 2009, 13:11 »
In which case, you might want to read this, Andy.
Sorry, I can't help with the caching thing either, but I trust what Rik says.  :)
« Reply #3 on: February 15, 2009, 13:16 »
Are you really really sure? ;D
« Reply #4 on: February 15, 2009, 13:28 »
Well, now you've said that...   :P
« Reply #5 on: February 15, 2009, 14:30 »
if you serious then try the live version of Ubuntu - http://www.ubuntu.com/  and welcome real computing into your come :-D
Offline topquark
« Reply #6 on: February 15, 2009, 16:23 »
No caching per se.  However if any of them are archive (.zip etc) files then windows explorer will try to discover the directory contents for them; which, if they are large, may take a long time.  It is possible to unregister the dll that handles this if you wish using regsvr32:
Code: [Select]
regsvr32 /u C:\Windows\System32\zipfldr.dll
Reverse the polarity, it'll be fine !
Offline Andy K
« Reply #7 on: February 15, 2009, 23:25 »
I managed to do the job, by using a USB stick. Why I didn't use this in the first place I don't know  :)x
The files were driver files.
I take a look at the link thanks
« Reply #8 on: February 16, 2009, 08:23 »
Glad you got it sorted, Andy.  :)
