April 19, 2025, 03:29
Technical Help & Discussion
Java
Topic: Java (Read 1174 times)
Java
February 15, 2009, 23:10 »
I've been told I have to use Java to view a remote machine but how do I know if it's installed on my machine? Is it safe to use because I have always understood that it should be avoided because viruses can hide in it? Where should I install it from and which version should I install? Thanks in advance for any input.
Sandra
Ultimate Member
Re: Java
February 16, 2009, 00:31 »
I think this is probably the best one for you Clive :
http://java.com/en/download/
I dont know why youd need it for remote viewing though, which program are you using ?
Re: Java
February 16, 2009, 08:22 »
You'll probably find it's installed anyway, Clive, as many websites require it. It'll be in your Add / Remove Programs list.
Re: Java
February 16, 2009, 09:21 »
Thanks Sandra and Simon. It's bespoke software called Coravel viewer which is to view an instrument attached to a telescope at Cambridge. I do in fact have it after all!
Java
