Author Topic: Linux For Anarchists  (Read 1372 times)
« on: February 17, 2009, 10:59 »
bit old now, but an interesting read:
Linux For Anarchists - http://www.thoughtcrime.org/writings/lfa.html
Re: Linux For Anarchists
« Reply #1 on: February 17, 2009, 11:33 »
The only thing the guide doesn't say is, what to do with all of your backed up documents, when half of them won't open with Linux.  ::)
« Reply #2 on: February 17, 2009, 11:43 »
They will all open with Linux....
« Reply #3 on: February 17, 2009, 11:53 »
MS Office documents?  Outlook emails?
I still have my old computer sitting here idle, and wouldn't mind trying it out on a proper PC, rather than that stupid Eee PC thing, but I just don't have time to start on something like that at the moment.
« Last Edit: February 17, 2009, 11:55 by Simon »
« Reply #4 on: February 17, 2009, 11:59 »
Ms office documents are simple - they all open in open office (which you can try on windows if you want), apart from publisher files, but you can get converters for those.
Outlook emails - I don't see why not, I'd expect you can import them into thunderbird.
« Reply #5 on: February 17, 2009, 12:18 »
No, you can't, Sam, at least, not simply.  That's one glitch with TB, you can't convert easily from Outlook / OE or vice versa.
« Reply #6 on: February 17, 2009, 13:18 »
are you sure, I'm sure when I did it, it was quite simple... (but that's simple to me, so possibly required quite a bit of effort)
http://support.real-time.com/tbird/oe_import.html
http://kb.mozillazine.org/Import_from_Outlook_Express
« Reply #7 on: February 17, 2009, 14:15 »
I think the challenge arises when you have multiple accounts in Thunderbird, instead of one global inbox, like in Outlook / OE, but I guess, if you were starting from scratch, you'd only have the one account to start with anyway.
