Author Topic: No Acrobat patch for 3 weeks  (Read 1150 times)
« on: February 20, 2009, 17:15 »
A security flaw in Adobe's Acrobat Reader software will not be fixed for three weeks, the company has warned.
Adobe warned that the vulnerability affected Acrobat Reader 9 as well as Acrobat 9 and earlier versions of the software as well.
"Adobe expects to make available an update for Adobe Reader 9 and Acrobat 9 by 11 March, 2009," Adobe said in a statement.
"Updates for Adobe Reader 8 and Acrobat 8 will follow soon after, with Adobe Reader 7 and Acrobat 7 updates to follow," the statement continued.
Security experts warned that the flaw could allow a hacker to take control of your PC.
"The risk is that hackers could deliberately construct a malformed PDF file that would trigger the vulnerability, allowing them to open a backdoor and run malicious code on your computer," said Graham Cluley of security firm Sophos.
Re: No Acrobat patch for 3 weeks
« Reply #1 on: February 20, 2009, 17:26 »
To think I used to be an ardent Adobe fan.  :cry:
« Reply #2 on: February 20, 2009, 17:28 »
its bloatwear too!
« Reply #3 on: February 20, 2009, 17:30 »
I know. :( When I worked for them, they 'felt' a much better company, they were lean, quick to respond, innovative. Now, they seem to have got bogged down in trying to out Microsoft Microsoft, Sam.  :bawl:
« Reply #4 on: February 20, 2009, 18:27 »
So, are PDF files something to be generally wary of?  I wasn't aware that they could harbour viruses.  What if you use something like Foxit to open them?  Would you be more vulnerable in that case?
« Reply #5 on: February 20, 2009, 18:43 »
You're as vulnerable as Foxit, Simon. It's like any piece of code you download, really, it can harbour nasties.
« Reply #6 on: February 21, 2009, 09:53 »
though its easier to hind things in certain types.. and you don't really execute pdfs....
« Reply #7 on: February 21, 2009, 11:10 »
Is that true, Sam? They are based on Postscript and, as such, do run code surely?
« Reply #8 on: February 21, 2009, 15:28 »
actually I guess you are right in that sense - I meant its not like you are going to run a pdf like you would some other executable, e.g. if you downloaded a programme of the web then you would expect to install it so when it started running a setup  you wouldn't think anything of it-  if a pdf did, alarm bells should ring.  If that makes sense...
« Reply #9 on: February 21, 2009, 15:35 »
It does. What I was thinking, though, was that a suitably crafted PDF could exploit Acrobat without the user knowing a thing about what was happening.
« Reply #10 on: February 21, 2009, 16:09 »
Wasn't there a huge spate of spam containing .pdf viruses about a year ago?  :dunno:
« Reply #11 on: February 21, 2009, 16:35 »
true... though there probably aren't that many pdfs out there that are infected - you still have to get it from a dodgy source.
« Reply #12 on: February 21, 2009, 16:37 »
Yes. :(
