Author Topic: yontoo or java or ie8 ? heelp  (Read 11842 times)
Offline Michelle
    • Techieminx
Re: yontoo or java or ie8 ? heelp
« Reply #30 on: February 21, 2009, 17:52 »
they might be too small now lol - i am still typing however and no freezes?
Offline Michelle
    • Techieminx
« Reply #31 on: February 21, 2009, 17:53 »
oh wheres the other one............. first one again
« Last Edit: February 21, 2009, 17:56 by Michelle »
« Reply #32 on: February 21, 2009, 17:54 »
thanks lol - max size 250kb? oh lol
Isn't that big enough for you?  [wtf]
yes i restored to last week and ie8 went very odd indeed lol and i couldn't do anything? it wouldn't let me in internet settings ?  so i restored it back
In which case, if it were me, I would probably restore back again, then reinstall IE8.
Offline Michelle
    • Techieminx
« Reply #33 on: February 21, 2009, 17:55 »
it wouldn't let me reinstall either at that date, but maybe i could use another date.......... mind you its still working.
« Reply #34 on: February 21, 2009, 17:56 »
That number of processes is still very high, Michelle, and you need to examine the system to see what they all belong to. The quickest way would probably be by disabling them using MSConfig, then seeing what won't work.
« Reply #35 on: February 21, 2009, 17:56 »
Michelle, TeaTimer is part of Spybot Search & Destroy.  Go into the Spybot options, and try turning TeaTimer off.  It may be conflicting with Super Anti Spyware, or your other security.
Offline Michelle
    • Techieminx
« Reply #36 on: February 21, 2009, 17:57 »
alot of them are on there 2 or 3 times?? is that normal? like scvhost.eve.......
« Reply #37 on: February 21, 2009, 17:58 »
By the way, in case there's any confusion, the 250Kb attachment limit is the file size, not the actual size of the image, yes?
« Reply #38 on: February 21, 2009, 17:59 »
That's usually OK, but 'iexplore.exe' (IE) shouldn't be running twice, as far as I am aware.
Offline Michelle
    • Techieminx
« Reply #39 on: February 21, 2009, 18:01 »
ohhh ...... i don't think it was before either
Offline Michelle
    • Techieminx
« Reply #40 on: February 21, 2009, 18:02 »
yes thanks, mine were bmp's so they were like 2mb lol - ah its gone slow
Offline Michelle
    • Techieminx
« Reply #41 on: February 21, 2009, 18:05 »
gss is back?!?  :crazy: :thumbs:
« Reply #42 on: February 21, 2009, 18:07 »
That's normal, most shouldn't be duplicated though.
« Reply #43 on: February 21, 2009, 18:08 »
Well, we think it's him...   ;)
« Reply #44 on: February 21, 2009, 18:09 »
Quoting my own post, in case you missed it, Shell.  :)
