Author Topic: XP to Vista,is it possible  (Read 6798 times)
Offline David
  • http://Wormdive_2
« on: February 23, 2009, 10:35 »
I have a desktop pc which is running XP will run SIW later,is it possible to install Vista rather than XP ?
Just a thought.Am I correct in thinking if the spec of the machine is enough then changing the OS is possible ?
Re: XP to Vista,is it possible
« Reply #1 on: February 23, 2009, 11:24 »
You can always upgrade the OS if the hardware will handle it, David, though whether Vista is an upgrade is debatable.  :devil:
Offline David
  • http://Wormdive_2
« Reply #2 on: February 23, 2009, 12:31 »
 ;D ;D You know I live Vista  ;) I will log it on later would MS be the only site to,I assume download it ?
I LOVE VISTA
« Last Edit: February 23, 2009, 12:36 by David »
« Reply #3 on: February 23, 2009, 12:34 »
That's the problem with it, it takes over your life. ;D
Offline David
  • http://Wormdive_2
« Reply #4 on: February 23, 2009, 12:38 »
It is imho far more user friendly though and I think its far easier to sort out things which go wrong from time to time as opposed to XP which personally I find much more complicated  ;D
« Reply #5 on: February 23, 2009, 12:59 »
I grew up with DOS, so I guess that, for me, XP is simpler because I can still get my hands dirty. MS progressively likes to remove the amount of control we have with each successive OS, and it's partly that which makes me reluctant to take on Vista.
« Reply #6 on: February 23, 2009, 14:18 »
agree with you there Rik, I like Linux cause I can get my hands dirty.
« Reply #7 on: February 23, 2009, 15:13 »
One day you'll convert me, Sam, or I'll buy a Mac. :)
Offline Myst
« Reply #8 on: March 20, 2009, 21:52 »
Rik, you grew up with an abacus m8  :P
« Reply #9 on: March 20, 2009, 22:35 »
Ah, but Clive learned to write on slate.  :)x
« Reply #10 on: March 20, 2009, 22:50 »
Rubbish!  In my days we used stone chisels on the walls of our caves!
« Reply #11 on: March 20, 2009, 22:55 »
 :arf:
Offline captainhaddock
« Reply #12 on: March 21, 2009, 08:32 »
I have just finished off a box I had built, I tried to install Vista business using an unregistered legit copy from work, but it wouldn't have it as it was an upgrade and said that I would require a previous windows installation with SP2. I then used an old OEM windows XP from a Dell machine we no longer use and installed that but because it was an OEM and had been previously registered it would not allow me to use Windows update to install SP2 ???
I rang MS and explained the situation, they said that I could download a new key and get a new copy of XP sent to me for £60.00. Did this and then installed Vista business and hey presto, working fine (well after some conflicts)
I must be one of the very few people who like Vista  ;D
« Reply #13 on: March 21, 2009, 11:20 »
I should think, after all that, you'd be spiting yourself not to like it!  ;D
« Reply #14 on: March 21, 2009, 12:27 »
Naah, fingers. ;)
