Author Topic: Browser problem.  (Read 1219 times)
Browser problem.
« on: March 15, 2009, 05:04 »
If your running nod32 and your browsers all die except for IE 64bit then you probably had a badupdate from nod. Go to the command prompt and run this command netsh winsock reset. If that doesn't work then uninstall nod. I fooled with my computer for an hour today trying to sot that out.
Online Simon
Re: Browser problem.
« Reply #1 on: March 15, 2009, 10:34 »
Thanks for the heads up, Bob.
