Author Topic: unexpected Shutdown  (Read 2396 times)
Offline Jaminxz
unexpected Shutdown
« on: May 20, 2009, 16:08 »
Havent posted on here for a while so hi guys!
Got a slight problem with my laptop. Its fairly decent spec so i can play some games on it. When i do play a game, occaisionally the whole laptop just switches its self off, i'd say this happens 1 in 3 times I play a game. It doesnt shut down or anything, just complely loses power almost instantly.
Also on another (possibly unrelated) note, whenever it is on it lets of a high pitched 'screech' about once an hour, sometime more frequently.
Hopefylly someone can shed some light on what might be causing this? Just to clarify, i havent changed in in any way since I bought, it runs vista 64, and has 4gb ram
Re: unexpected Shutdown
« Reply #1 on: May 20, 2009, 16:21 »
It sounds like you have a very dusty laptop which is overheating. My guess would be the screech is a clogged fan.
« Reply #2 on: May 21, 2009, 00:32 »
My thoughts too Rik  :)
Offline Jaminxz
« Reply #3 on: May 22, 2009, 17:00 »
ah. Think i shall be returning it for repairs seeing as its still under warrenty.
thanks for your help guys.
