Author Topic: Defraging again & again?  (Read 5929 times)
Offline Kaz
« on: May 31, 2009, 21:52 »
I have defraged my pc and after it says defraged successfully, so I do an analysis (straight after defraging) and it says it needs defraging again why is this why isn't it defraging completely?
Re: Defraging again & again?
« Reply #1 on: May 31, 2009, 23:14 »
I'm not one for defragging, but what software are you using to do it, Kaz?
« Reply #2 on: June 01, 2009, 03:58 »
----> Defragmentation Wikipage
There are some files which are unmoveable while windows is running. These types of files can stand in the way of your computer hard drive being 100% organized. If I were you I wouldn't worry about it.
Defragmentation doesn't do much good these days. Back in the old days when hard drives were relatively small and slow it was necessary to arrange the data in the most efficient way possible. This gives slower machines a small boost in performance. Nowadays though processors aren't measured in hundreds of megahertz, they're measured in thousands of megahertz or... gigahertz. Since computers have all this horse power you won't likely be able to sense a difference when you defrag. What little good defragging does do will not be compounded by consecutive runs of the defrag program. It's like organizing your spice rack. You only need to do it every few years depending on how messy things get.
Most people are trying to get their computers to run a bit quicker when they run windows defrag. Odds are you'll get a larger speed increase by clearing out your cookies and cleaning out old registry keys. Ccleaner does both. It's free and you can get it ------> here
« Last Edit: June 01, 2009, 04:07 by Reno »
« Reply #3 on: June 01, 2009, 09:57 »
It's quite common to need to do a second pass, Kaz, to 'pick up the bits'. Some software, such as Perfect Disk, will allow a boot-time defrag which will do a more thorough job.
Offline Kaz
« Reply #4 on: June 01, 2009, 12:01 »
I use Windows own defrag of Tuneup Utilities
Offline Kaz
« Reply #5 on: June 01, 2009, 12:02 »
Do you use this Rik?
« Reply #6 on: June 01, 2009, 12:37 »
I do, Kaz, and rate it very highly.
Offline Kaz
« Reply #7 on: June 01, 2009, 12:55 »
I will try it then, where can I get it from please?
« Reply #8 on: June 01, 2009, 15:32 »
http://www.perfectdisk.com/
Unfortunately, a 25% off offer ended yesterday.
Offline Kaz
« Reply #9 on: June 01, 2009, 16:34 »
thanks Rik
« Reply #10 on: June 01, 2009, 18:19 »
 :brickwall:... Have either one of you ever used performance testing software to actually see if your getting a performance change? Don't take my word for it that defragging is a waste of time. Do a system test for yourself. http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html
If there is actually a significant change in your hard drive's response time I'll quit my harping and eat my words.
« Last Edit: June 01, 2009, 18:29 by Reno »
Offline Kaz
« Reply #11 on: June 01, 2009, 20:10 »
Have you got any tips on this Rik and can you use it while you are working on your PC?
Offline Kaz
« Reply #12 on: June 01, 2009, 20:12 »
Have you use this Reno?
« Reply #13 on: June 01, 2009, 21:19 »
If it's called Sandra, there can't possibly be anything wrong with it.  ;)
Offline Kaz
« Reply #14 on: June 01, 2009, 21:36 »
Well That sure is right Simon :gogogo: GIRL POWER :gogogo:
