Author Topic: Help with Entertainment set up  (Read 6277 times)
Offline kotsoiandm
« on: June 01, 2009, 10:28 »
Can anyone give me a clue how to connect-up the following ;;;;
  1. NEC LCD TV with HDMI,VGA (in) , YPbPr (in) , ANT , S Video , RCA AV Inputs x 2 , Outputs x 1
  2. Teac 5.1 Home Th Receiver(AG20D) with HDMI (out x 1 , DVD In x 1 and AV In x 1 ) , RS232 , S Video(Monitor out x 1 , DVD in x 1 , AV in x 1) , Video IN/Out -( Vid out for RCA to TV ,V1 &2 In for external players , Digital in -AV1 , AV2 and DVD(optional) , Analog in /out - (Tape out /in , Aux in , AV 1&2 in and DVD in .
  3.  Bauhn HD Pers Vid Recorder  with Ant in/out , HDMI , VGA , Coax , S Video , RCA , YPbPR , Digital Audio (coax/optical) , RS232 and VGA Connector
  4.DVD Player (Highlander DVX4350) with RCA out , YPbPR , S Video out .
  5.DVD Player/VCR (LG V271) with Ant In/out , S Video out (DVD only) , Coax (Dig Audio out-DVD only) , YPbPr , RCA DVD/Video out , RCA Video in (VCR in AV1)
  6.Digital Sat receiver with Sat in , if out , TV Scart , VCR Scart , S/PDIF Digital out , RCA , Ant in (TV via loop optional) , and TV out (TV via RF cable optional  .
Its all a bit much to understand , but if you can tell me what to connect to what via whatever type of lead , Ill be ok . Thanks Ivan .
Re: Help with Entertainment set up
« Reply #1 on: June 01, 2009, 11:07 »
Hi, and :welcome:
If nobody beats me to it, I'll come back to on this later.  Are you starting from scratch with just a stack of equipment, and have you got all of the required leads?
« Reply #2 on: June 01, 2009, 13:37 »
HDMI is the best connection followed by component (YPbPr) followed by VGA. I assume that you are in the USA and not in europe as you havent mentioned any scart connectors, apart from on the sat receiver, but have RCA in, so the next best would probabl be Svideo followed by RCA.
I would connect the receiver via HDMI to the TV, dont be conned into buying an expensive HDMI cable as its digital and doesnt have the same problems as you get with cheap analogue cables.
Connect the Bauhn via HDMI to the receiver.
Have you not got component in on your receiver, red, green and blue RCA ?
If you have then use those for the Highlander
Can you take good quality photos of the back of the receiver so we can check exactly what type of conectors you have available before I carry on with the other boxes  :)
Offline topquark
« Reply #3 on: June 01, 2009, 15:51 »
I'd do as Sandra has suggested  ;D
...  dont be conned into buying an expensive HDMI cable as its digital and doesnt have the same problems as you get with cheap analogue cables....
Just try and keep the hdmi cable path clear from any power cables en-route to the TV coz some of the cheaper ones aren't as well shielded, although as Sandra says they are digital and it's have to be darn noisy to cause enough interference to cause a problem.
Reverse the polarity, it'll be fine !
« Reply #4 on: June 01, 2009, 21:01 »
Going by the email, I would have assumed this member was in Australia, but carry on, San, you're doing a grand job!  ;D
Offline kotsoiandm
« Reply #5 on: June 05, 2009, 08:44 »
Thanks . Yes I am in Australia and I do have all leads
« Reply #6 on: June 05, 2009, 11:11 »
Hi Ivan, thanks for your PM. I see you've found the Reply button now.  :thumb:
Let us know how you get on with Sandra's suggestions, and come back to us if you need further help.  :)
Offline kotsoiandm
« Reply #7 on: July 14, 2009, 02:12 »
to Simon and others who responded , thanks .
« Reply #8 on: July 14, 2009, 03:37 »
Ivan has emailed me the info of the various boxes.
I havent time to study the pics at the moment but will hopefully work something out by wednesday, unless someone else can.
http://i288.photobucket.com/albums/ll182/staylor51/setup.jpg
After a quick look as he has a lot of connections on the amp then it looks like most stuff should connect via that then from there to the TV :)
« Last Edit: July 14, 2009, 03:40 by Sandra »
« Reply #9 on: July 26, 2009, 10:29 »
Hi Ivan,
Have you got any further with this?
Offline kotsoiandm
« Reply #10 on: July 29, 2009, 00:00 »
SIMON . No mate . SANDRA is still getting back to me .  IVAN
« Reply #11 on: July 29, 2009, 00:14 »
Sorry for the delay Ivan, I have been so tied up these last few weeks I havent even had time to upgrade the image on my satellite receiver yet, or answer another question on here about building a new pc.
The pics you sent me werent really clear enough so I am going to see if I can find the backs of the equipment on the manufacturers websites to hopefully get a better idea.
I had left monday clear, or thought I had, until I got a few phone calls with pc problems to sort out.
I will try and get something sorted out for you this week.
« Reply #12 on: August 01, 2009, 19:32 »
Wow, I cant believe its taken me so long to reply but here it is :
Ok you need to connect the HDMI out of your TEAC to the HDMI in of your TV.
Connect the HDMI out of your Bauhn HD PVR to HDMI in AV 1 of the TEAC.
The Highlander connects via the YPbPr (also known in the UK as RGB, for Red Green and Blue or Component) to the TV via YPbPr, you also need a coax lead, single RCA from the box to the TEAC Digital Input AV1 coax.
The LG can connect via the S Video out direct to the TV S Video in.
You also need a coax lead, single RCA from the box to the TEAC Digital Input AV2 coax
For the Satellite receiver, (if your TV doesn’t have a Scart socket, the picture you sent doesn’t show one), then unfortunately you will have to either use a scart to S Video adapter or use the Composite Video out (Single RCA yellow socket) to the Composite in on the TV.
The S/PDIF audio on that box has an optical out so you need to connect that to the TEAC Digital Optical DVD.
So you need 2 x HDMI to HDMI cables, as stated earlier digital is digital so you don’t need to go for those overpriced so called professional quality leads. I use £5 and under leads when I can get them and have had no problems.
1 x component lead (YPbPr or RGB) 3 x RCA at each end, quality cables can make a difference here if you are using a long run as its analogue but again for a short run cheapies should be ok.
I x S Video lead as with the RGB cable only need quality if on a longish run.
1 x RCA cable, yellow for convenience as the connections on the TV and the satellite receiver are yellow.
2 x RCA for the digital coax, these are digital so again cheapies are fine. I would probably use a paired white and red RCA if your Highlander and LG are close enough for you to be able to split the wires to connect for the audio as its probably cheaper and neater than having 2 single RCA leads.
1 x Optical cable, again, if light goes in one end and comes out the other then that’s all that matters, no need to pay silly money for better quality.
I hope that I have explained what you need and how to connect everything up in an easy to follow way.
I am sorry its taken me so long to find time to make a full reply.
Clearer pictures would have possibly helped but I managed to download the TEACs manual :)
« Reply #13 on: August 01, 2009, 23:00 »
Sandra as ever helping the poor a needy of the PC and visual entertainment world. She really should be knighted........I'm not kidding folks
« Reply #14 on: August 02, 2009, 01:08 »
Hi Tony, how you doing ?
Hope the wife and mother in law are fully recovered now  :)
That TEAC AV amp is unusual in that it has all those HDMI connections but no component (RGB) in or out and the non HDMI inputs arent upscaled and then output via the HDMI.
