Author Topic: Adblock Plus  (Read 1773 times)
Adblock Plus
« on: July 14, 2009, 12:25 »
Does anyone use this, or am I asking for trouble?  Does it work, or is it just designed to crash the browser?  A couple of local news sites I go on have so many ads on them it is like walking along Blackpool Prom during the Autumn illuminations just looking at the screen.
Thanks.
Re: Adblock Plus
« Reply #1 on: July 14, 2009, 13:19 »
I've known people to use it, with mixed results, but only on Firefox, Dave.  It may work better on SeaMonkey, but bear in mind, it's not as easy to uninstall add-ons from SM as it is from Firefox, so I would suggest installing Extension Manager before trying any other add ons.  :)
Re: Adblock Plus
« Reply #2 on: July 14, 2009, 13:40 »
Thanks, Simon.  I was sort of aware that some people have had problems after installing it.  Having thought about it, as it is only these two local news sites that annoy me, I think I'll give it a miss.
Thanks again.
Offline Baz
Re: Adblock Plus
« Reply #3 on: July 14, 2009, 14:03 »
I use it Dave and its been good.Had a little bit of bother a while back with slow page loading and people suggested it may be Adblock but I never confirmed it was. It just runs and stops all the crap to be honest, when I go back onto IE  :ack: its surprising how much it does block out.
Re: Adblock Plus
« Reply #4 on: July 15, 2009, 19:01 »
I've used it for years. I used just regular adblock before ABP came out. All it does is filter the web using a blacklist of domains. If the ad is still appearing all you need do is add it's domain to the blacklist and presto, no more ad. If anything it should speed your browser up, because it spares it from having to load craptons of flash ads.
Re: Adblock Plus
« Reply #5 on: July 16, 2009, 02:00 »
Cheers, Bob, I'll try it.
