Author Topic: Wireless N technology for a Dell laptop Inspiron 1525  (Read 4064 times)
Offline andyhx
Hi
Any advice appreciated about the best choice of Wireless N router for home use with an Inspiron 1525 with mini WLAN card that only works with 8.01b/g.
thanks
Andy
Re: Wireless N technology for a Dell laptop Inspiron 1525
« Reply #1 on: July 29, 2009, 21:21 »
Rik will be your best one for this (probably), and he won't be around until the morning now, Andy.  :)
Offline Camstop
« Reply #2 on: July 29, 2009, 23:48 »
There's a good selection here<.
I occasionally work along side a network company and they swear by Draytek, but that's for commercial situations.
Draft N is backward compatible so Your network card will work with the draft n router but only perform at the cards speed.
You could upgrade your card to this< (best double check that's the right card for your laptop) if you wanted the full draft N experience which would give you longer range and faster networking.
edit: This one gives you a USB adaptor if you didn't want to change your laptops card http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=7260
« Last Edit: July 29, 2009, 23:52 by Camstop »
Offline andyhx
« Reply #3 on: July 30, 2009, 21:18 »
Thank you
Andy
