Author Topic: Snow Leopard protects you from two Trojans  (Read 1498 times)
Re: Snow Leopard protects you from two Trojans
« Reply #1 on: August 29, 2009, 09:50 »
My Mac OS ain't broke so I'm not gonna fix it.   8-)
« Reply #2 on: August 29, 2009, 09:52 »
How exactly are Macs 'immune' from viruses and trojans?  Is it just because no one has bothered to target them?
« Reply #3 on: August 29, 2009, 10:17 »
I think so Simon.  But MacOS updates every time you turn it on - or so it claims.  I have no protection whatsover on it.   :dunno:
« Reply #4 on: August 29, 2009, 15:01 »
it also helps that they have proper port management and by default everything isn't open...
« Reply #5 on: August 29, 2009, 16:31 »
Isn't that what any decent router should achieve, though?
« Reply #6 on: August 30, 2009, 05:59 »
yes... but the point is most people dont have a router.
« Reply #7 on: August 30, 2009, 11:02 »
Umm... don't they?  I would have thought, with broadband, most people now do have a router.  :dunno:
« Reply #8 on: August 30, 2009, 15:55 »
you don't need to  - most allow you to connect straight to the modem. I guess as people have gone more an more wifi then you might be right.
