Author Topic: Firefox crashing.  (Read 3253 times)
Firefox crashing.
« on: August 31, 2009, 09:21 »
Firefox automatically updated a week or so ago, and ever since it's been crashing.  >:(
How do I go back to the previous version or uninstall the updates?
I wasn't going to worry about it and hope that it would sort itself out with all the reports I've been sending to Firefox, but it's getting beyond a joke.
Re: Firefox crashing.
« Reply #1 on: August 31, 2009, 10:55 »
What add ons do you have?  It could be one of them struggling with the update.
« Reply #2 on: August 31, 2009, 11:17 »
Add Block Plus
Bug Me Not
Download Helper
Firefox Showcase  (didn't know I had this one)  :dunno:
Smiley Extra
StumbleUpon
TVU Web Player
Web Mail Notifier
And a couple that aren't functioning, and one that is odd.
Smiley Extra 4, which has been out dated, but I use it occasionally as the other one is rubbish.
Microsoft . NET Framework Assistant ??
« Reply #3 on: August 31, 2009, 12:36 »
Disable them all, MB, see if FF is then stable. If it is, enable them one by one until you identify the culprit.
« Reply #4 on: August 31, 2009, 12:43 »
I find Firefox tends to freeze when it hits websites which are rich in embedded video.
« Reply #5 on: August 31, 2009, 13:01 »
Adblock plus can cause crashes at times
But it does seem after the update firefox has began to use more CPU and memory
There are workarounds on the net
Like Rik said disable the addons and start them one at a time untill the crashes stop
« Reply #6 on: August 31, 2009, 14:54 »
Thanks everyone.
This happened to me last time Firefox updated.
I don't really need most of the Add ons, the only one I need is Web Mail Notifier.
So I'll disable all of them and see how I go.
And I think you're right Gill, as soon as I open a few tabs with high demand content the cpu goes nuts and it's not long before the Firefox debug thingy pops up.
What are the workarounds, Davy?
« Reply #7 on: August 31, 2009, 16:39 »
flashblock plus works to an extent
There is a tweak that you can do with the new firefox it helps the CPU a bit
A word of caution remember what you changed keep notes so you can undo them if necesary
These will speed up firefox and help some
read down the page
http://kb.mozillazine.org/Firefox_CPU_usage
http://just-thinkin.net/2008/05/firefox-3-rc1-high-cpu-and-memory-use-try-this-fix/
http://www.wikihow.com/Stop-Firefox-from-Consuming-Your-Cpu-Cycles
« Reply #8 on: September 01, 2009, 12:25 »
I'm not having any more problems, well with firefox, at any rate.  ::)
But I can't believe the amount of ads on some sites  :o  Unbelievable!!
Even bloody ebay. And the funny thing is, some of these ads are for counterfeit DVDs, bloody hysterical.  :haha:
I did have one error message. Ash Web Sv. exe Application Error Break Point
Michael said it had to do with running out of memory or something??
« Reply #9 on: September 01, 2009, 14:03 »
Ash Web Sv. exe is the web protection for avast anti virus it will crash on some web pages
its not a real problem it repairs itself
adblock plus will stop some of the adds on pages but then it can slow down or cause firefox to crash
« Reply #10 on: September 01, 2009, 14:07 »
Thanks Davy, that's great.  :thumbs:
Nice to know what the problem was. I could do without all the ads though.
« Reply #11 on: September 03, 2009, 10:14 »
It's still crashing, well once or twice.
How easy is it to go back to a previous version?
Preferably one that is a little more stable and one that I can use a proxy with.
Oh, and which proxy is the best?
I've had a look at proxy addons for firefox.
« Last Edit: September 03, 2009, 10:16 by mistybear »
« Reply #12 on: September 03, 2009, 11:38 »
Firefox is very flakey these days.  Why not try an alternative like Seamonkey or Opera?
« Reply #13 on: September 03, 2009, 14:05 »
seamonkey or Google chrome are better choices
If you definately want to go back to an earlier firefox they can be found here
http://www.oldapps.com/old_version_list_web_browser.php
But I will warn you you will lose all passwords and store info on firefox  and some of the older versions just dont work anymore
The most stable version was 2.0 and before
and they do have security problems
