Author Topic: Advice on building a new HTPC  (Read 4803 times)
Offline elsmandino
« on: September 19, 2009, 21:12 »
Hello.
I am building an HTPC, which has got to be quiet and efficient. It will not be used for gaming, but has to be capable of producing full 1080p picture quality/playing blu-ray.
The computer is going to be plugged into my tv in the lounge and I eventually intend to wire cat6 all over my house, via a gigabyte router - so I can stream live or recorded tv to two other televisions via media extenders.
I also have a sat dish with twin lnb and an external aerial, so the computer has got to be capable (in the unlikely event) of recording two channels, whilst allowing live tv to be watched in the living room as well as streaming a recording to one of the media extenders all at the same time - this will not happen very often, but probably will happen eventually.
The computer is going to be used as a replacement for my DVR, so it needs to come out of sleep mode properly and come on automatically to record and return to S3 afterwards.
I have come up with the following spec machine and would be really grateful for you comments and any changes you would suggest - or any incompatibilities I may have missed.
Hard drive - F3 1TB Samsung (I looked at 5400 rpm hard drives, but although they are quieter, decided that I would need a 7,200 rpm hard drive for simultaneous recording and streaming)
PSU - Corsari 550VX
Mobo - Asus MSN78-EM (this has 2 x pci slots, 1x pci 1 and 1 x pci 16 and NVIDIA GeForce 8300 chipset)
TV Tuner cards (three of them) - 2 PCI Hauppage WinTV Nova HD S2 Tuner cards (for two freesat channels) and 1 Hauppauge HVR 2200 MCE Dual Hybrid PCI Express card (for two digital channels)
Case - Antec Fusion Remote Max
CPU - Athlon II x2 240
OS - Windows 7, using media centre as the front end
Optical Drive - LG Blu-Ray
RAM - 2 x 2GB 800Mhz DDR2 RAM (I know that 2GB would be enough, but RAM is pretty cheap so thought I would go the whole hog)
Your comments would be greatly appreciated before I take the plunge
Thx
Re: Advice on building a new HTPC
« Reply #1 on: September 19, 2009, 21:50 »
Hopefully, Sandra will be able to help you with this.  :)
« Reply #2 on: September 20, 2009, 00:45 »
I would rather go for an intel based system, either core 2 duo quad or the i7 if you can afford one, rather than the AMD ones.
If you are on a budget and need to go with AMD then you should really be going for one of the phenom cpus.
I would suggest that you get a mobo without onboard graphics and use a seperate graphics card, providing you get a mobo with enough PCI-e slots to take all the tuner crads and graphics cards you need.
Of course with a good seperate graphics card you would probably need a more powerful PSU than the one you have specified.
If you are doing a lot of watching, recording and streaming of HD content then you need as powerful a pc as possible, with increasing performance comes increased heat and therefore noise.
This is why I would recommend Intel over AMD as they run cooler and so will be quieter for the same or more power these days, and using a seperate graphics card will not take as much out of the cpu and will have its own ram as well.
Hope this helps :)
« Last Edit: September 20, 2009, 00:50 by Sandra »
