November 28, 2024, 00:37
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
Firefox not saving cookies
Topic: Firefox not saving cookies (Read 2591 times)
daveeb
Loyal Member
October 03, 2009, 15:32 »
Hi Guys as stated above I have to log in to all sites each time i use them (has only happened recently). Checked the cookies folder which is virtually empty apart from google and pc pals !! even pals asks me to log in each time. Passwords are all remembered so i don't have to type them out each time but it's still annoying. FF is set to remember history using custom settings. I haven't set it to clear cookies or history on close down. I updated from v 3.0.14 to 3.5.3 to see if that helped which it didn't. Any ideas ?
Re: Firefox not saving cookies
October 03, 2009, 15:43 »
Get hold of the CookieCuller addon. You can then selectively protect or remove cookies. Do you have any other cleanup utility acting at shutdown?
October 03, 2009, 17:24 »
Is FF set to clear cookies after each session, Dave? Failing that, as Rik said, do you have anything such as CCleaner running in the background, or at startup / shutdown? Something is obviously clearing the cookies. We just need to find out what.
Baz
Established Member
October 03, 2009, 19:04 »
there is a new feature in that version of FF which doesnt save anything at all, it might have been enabled by mistake from Tools>Start Private Browsing.
daveeb
Loyal Member
October 03, 2009, 19:49 »
Thanks for the replies all, but I don't have anything cleaning up at shut down and FF definitely isn't set to clear cookies on shutdown and i'm not using private browsing. Even stranger is that the cookies can be there one minute (i've been checking after visiting certain sites) if i browse away then go back i have to log in again. When i check the cookies sure enough they've disappeared. Seems very strange that they can disappear even within the same session. Equally odd is that the only cookies that seem to persist are some google ones and the pc-pals (2 of them) although i still have to log in each time. I can't pinpoint the start of the problem but probably quite recent. I think i might have to uninstall FF and start again, there's clearly something amiss. ':|
October 03, 2009, 19:53 »
Does the same happen in another browser, such as IE or Sea Monkey, Dave? The answer to that might determine if it is FF, or something else in your machine.
Baz
Established Member
October 03, 2009, 20:53 »
is
this
any help
daveeb
Loyal Member
October 03, 2009, 21:55 »
@ Baz and Simon
Thanks guys for the ideas. I've uninstalled and reinstalled FF but problem persists. I'll try IE as you suggest Simon. Baz i'd googled and discovered your suggestion which i'll also try. I'm fairly sure that one of my malware programs is killing the cookies but not sure which one or why it has just started doing it. I'll get back tomorrow when i get chance to try out your ideas.
daveeb
Loyal Member
October 03, 2009, 22:32 »
Problem solved apparently ! Baz's idea worked i.e. a corrupt cookie folder was the culprit. rename the .sqlite file to .tmp. I presume a brand new sqlite folder is then created. Anyhow it worked so thanks to Baz Simon and Rik.
Baz
Established Member
Reply #9 on:
October 04, 2009, 08:24 »
pleased you got it sorted Dave
I hate the problems that get you stumped like that but its great to solve them.
nice one
Smiley fixed - Simon.
Last Edit: October 04, 2009, 11:17 by Simon
Reply #10 on:
October 04, 2009, 11:17 »
Nice one, Baz!
Reply #11 on:
October 04, 2009, 11:47 »
I'd give you a karma, Baz, but we're in the wrong place.
Baz
Established Member
Reply #12 on:
October 04, 2009, 19:45 »
thanks all............
a karma IOU will do Rik
