Author Topic: Linux T+180 days  (Read 1593 times)
Linux T+180 days
« on: October 27, 2009, 16:47 »
http://linuxlock.blogspot.com/2009/10/linux-t-180-days.html
Interesting read about people trying out linux, I don't at all agree with the ipod support comments - all the major audio tools seem to do this, I use rhythmbox
Re: Linux T+180 days
« Reply #1 on: October 27, 2009, 21:08 »
"When I have desktop effects enabled, there are times when I click something and the screen darkens for up to a minute before anything happens and after that my computer runs slow. When I turn off the effects it fixes itself. I have a one year old computer running two gigs of ram. This should not happen." Juanita - restaurant server
Noted this myself and not quite sure why this happens. I only run effects on my demonstration laptop...only so long I can tolerate wobbly windows and pretty sparkles before they get annoying or in the way of my work.
I find this happens all the time on the EeePC, running Ubuntu, and it's annoying enough to stop using it.  :dunno:
« Reply #2 on: October 28, 2009, 00:25 »
its just the programme crashing... though it shouldnt happen often...
« Reply #3 on: October 28, 2009, 11:54 »
It happens all the time, especially when I'm on here with it.  I was wondering if it was the flash animations, but it does it almost as much on Netters too, and they don't have any.  :dunno:
« Reply #4 on: October 28, 2009, 21:38 »
using firefox? could be the flash animations.. but that doesn't explain both sites.
« Reply #5 on: October 28, 2009, 21:39 »
Yup, Firefox.  :dunno:
« Reply #6 on: October 29, 2009, 02:32 »
did you install ubuntu at all, or are you using the default os that came with it?
« Reply #7 on: October 29, 2009, 11:31 »
No, I binned the original OS, and have Ubuntu on it.  Curiously, I didn't get this problem with the old OS, but it was just pants anyway.
« Reply #8 on: October 29, 2009, 13:45 »
that's odd - you could try a different webbrowser, just in case it is firefox. I'd suggest epiphany. If its not on there you can install it by going to the menu > applications > Add/remove... or if you are feeling confident, just open up a terminal and type:
sudo apt-get install epiphany
(it will ask you for your password)
« Reply #9 on: October 29, 2009, 15:08 »
OK, I'll try it.  Thanks, Sam.  :)
« Reply #10 on: October 29, 2009, 23:09 »
Well, it does seem to work better, but I need to fiddle with it a bit.  It looks quite dated, with the huge icons, and it hasn't imported my passwords from Firefox, so that could be a bit of a faff.
« Reply #11 on: October 30, 2009, 02:07 »
yeah, its not as good as firefox in any respect, but thought it would be worth a go...
you could always try upgrading firefox...  either by the package browser or by typing:
sudo apt-get upgrade firefox
« Reply #12 on: October 30, 2009, 08:09 »
I'll try that over the weekend.  :)
