Author Topic: WIFI problem  (Read 1777 times)
Offline jww41005
WIFI problem
« on: November 06, 2009, 17:34 »
OK Pals,
Get your thinking caps on!
The router has stopped broadcasting a signal. The PC and two laptops can connect to the net with a cable connection only. My laptop can pick up several other internet signals in the area, but not mine. I installed the software that came with the router, but it hasn't worked.
OS Vista basic (yes, I know!)
Here are the bios from the PC that the router is connected to:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\John>IPCONFIG /ALL
Windows IP Configuration
   Host Name . . . . . . . . . . . . : John-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet
 NIC
   Physical Address. . . . . . . . . : 00-17-3F-CE-30-58
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::48cc:106c:55ed:fff2%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.34(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : viernes, 06 de noviembre de 2009 11:27:40
   Lease Expires . . . . . . . . . . : lunes, 09 de noviembre de 2009 11:38:07
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 285218623
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-24-27-68-00-19-66-06-D9-ED
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
   Physical Address. . . . . . . . . : 00-19-66-06-D9-ED
Tunnel adapter Local Area Connection* 6:
   Description . . . . . . . . . . . : isatap.{C8BFFF3F-9331-4425-85A3-B2E3E22AB
48C}
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 02-00-54-55-4E-01
   IPv6 Address. . . . . . . . . . . : 2001:0:d5c7:a2d6:1004:12ea:3f57:fedd(Pref
erred)
   Link-local IPv6 Address . . . . . : fe80::1004:12ea:3f57:fedd%13(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 12:
   Description . . . . . . . . . . . : isatap.{0CA421FB-A935-48F8-B0AF-16FDADA7D
645}
Thanks for any help
John
If it works, don't fix it
Re: WIFI problem
« Reply #1 on: November 06, 2009, 17:47 »
Sounds like the wireless connection has died, John, do you have access to another router to test which end?
Offline jww41005
Re: WIFI problem
« Reply #2 on: November 06, 2009, 18:02 »
Hello Rik,
Nope, I haven't got another router.
Shall I try resetting the router?
Re: WIFI problem
« Reply #3 on: November 06, 2009, 18:13 »
Always worth a try.
Offline jww41005
Re: WIFI problem
« Reply #4 on: November 10, 2009, 09:26 »
Hello again,
Well, I turned everything off, turned the router on and reset it. I then turned the PC on and reloaded the isp software. I had to do this three times before it actually worked. I didn't really want to start playing about with the router, but at least it worked.
I think vista and kaspersky might have got in the way here.
Cheers
Re: WIFI problem
« Reply #5 on: November 10, 2009, 09:58 »
You shouldn't need any router software, John, as you're connecting via ethernet.
Offline jww41005
Re: WIFI problem
« Reply #6 on: November 10, 2009, 11:07 »
I think I needed the software to configure the router.
Anyway, before I could connect the PC and two laptops to the router by cable, and it worked, but the wifi wouldn't work. After resetting the router and running the CD again, the wifi works. I'm not sure why, but I don't care :thumbs:
Thanks Rik!
Re: WIFI problem
« Reply #7 on: November 10, 2009, 11:08 »
NP, glad you're sorted. :)
