Author Topic: silence of the lambs  (Read 12524 times)
Offline KRO
« on: November 09, 2009, 01:40 »
ok dont laugh, i have only very recently been getting the sound of bleeting lamb on my pc, does anyone have any idea's, a friend seems to think it might be a virus..(i do hope not) but i just seem to get this random...baa  ????
i am running vista home edition, and AOL are my broadband provider..and i'm currently running AVG free edition..thanks for any help..
cheers kro.....
Re: silence of the lambs
« Reply #1 on: November 09, 2009, 01:55 »
it does seem like some application might be running in the background... but a virus making noises like that, hmmm...
« Reply #2 on: November 09, 2009, 03:05 »
I had a trojan a few months back that started a program that sounded like a radio broadcast every so often for what appeared to be no reason or particular pattern.
If you open your task manager up when the noise appears, look in the processes part and see if theres something running thats just a letter then .exe
I had various ones coming up from a.exe to g.exe.
If you highlight it and click on End Process the sound should go.
If it t day, look in C/Temp folder and on mine I had all those a.exe and b.exe files in there. I deleted them all and after scanning with a trojan remover, malwarebytes, AVG and every other clean up program that I had it got rid of everything.
« Reply #3 on: November 09, 2009, 03:12 »
You had that too, Sandra?  My antivirus picked it up before it could do any damage, but I had to use the Sophos anti-rootkit to finally clear it.
« Reply #4 on: November 09, 2009, 03:26 »
Well it was my fault really Gill, I had downloaded something and scanned it and it said it was clean.
When I installed it and ran the keygen AVG, flagged it up as a trojan.
I assumed it was a false positive, as so often happens, and told it to continue.
Shortly afterwards all the problems started  :o:
« Reply #5 on: November 09, 2009, 05:15 »
Oh the fun of using windows.
« Reply #6 on: November 09, 2009, 09:20 »
Of course, it's always possible a lamb crept in to keep warm and now can't get out again.  ;D
« Reply #7 on: November 09, 2009, 09:45 »
This is not a joke question, but you haven't got a little cartoon sheep running round your desktop have you, KRO?
http://www.slinkycity.com/windows-desktop-sheep.html
If that's it, you should be able to remove it via Add / Remove programs.  If not, then sorry, I don't know.  :dunno:
Offline KRO
« Reply #8 on: November 09, 2009, 11:09 »
hi simon, no sheep just the sound, it's actually sounded off once so far this morning....
cheers kro.....
« Reply #9 on: November 09, 2009, 12:18 »
Anything odd in Task Manager, or in Add / Remove programs?  You could try running SuperAntiSpyware or MalwareBytes, in case it's spyware.
« Reply #10 on: November 09, 2009, 14:20 »
Download and run A-Squared it will find it and allow yyou to  follow it to the folder its in then you can delete it
Itg sounds like a trojan
A squares is slow but will find what others miss
http://www.emsisoft.com/en/software/free/
Offline KRO
« Reply #11 on: November 11, 2009, 22:59 »
hi,
    i'm still getting this sound periodically, i downloaded A-squared and ran a deep scan, which came up with 32 low risk cookies...should i delete all these ?.......thanks
cheers kro.....
« Reply #12 on: November 11, 2009, 23:04 »
No harm in doing so but no harm in leaving them either.  Could it be your fan making a noise?  :dunno:
« Reply #13 on: November 11, 2009, 23:07 »
hi,
was there any evidence in the task manager at all?
Offline KRO
« Reply #14 on: November 11, 2009, 23:12 »
hi sam,
          no it all seemed fairly normal in the task manager (but hey, i wouldn't have a clue what i was looking at really) at least there was nothing like sandra suggested there might be, ie: a single letter then .exe   ??? ???
cheers kro.....
