April 19, 2025, 13:21
Technical Help & Discussion
Apple, Linux & Open Source Software: Help, News & Discussion
5 More Free Linux Apps You Can't Do Without
Topic: 5 More Free Linux Apps You Can't Do Without (Read 926 times)
November 11, 2009, 16:16 »
http://www.pcauthority.com.au/News/160222,5-more-free-linux-apps-you-cant-do-without.aspx
I like transmission and in the past I used to use a webbrowser for my torrents (had a mysql backend) and was great as I could login to it from any machine and just get torrents going. I tend not to bother with that now though - given I'm working off my laptop all the time (ye olde desktop is all packed up my parents loft :-( )
Re: 5 More Free Linux Apps You Can't Do Without
November 11, 2009, 16:43 »
Installing them's the tricky bit.
November 11, 2009, 16:52 »
well myth yeah.. the rest should be just in the add/remove software - or open terminal sudo apt-get install programname
