November 27, 2024, 15:39
Food & Drink
Tuscan (Salt Free) Bread
Topic: Tuscan (Salt Free) Bread (Read 10240 times)
Re: Tuscan (Salt Free) Bread
Reply #30 on:
November 17, 2009, 16:46 »
Er, that's 1 teaspoon.
Reply #31 on:
November 17, 2009, 17:37 »
Reply #32 on:
November 17, 2009, 18:46 »
Don't worry, I knew what you meant!
I normally use 1/8 teaspoon but this time it was just a tiny pinch. It tasted really delicious so I will go the whole hog next time and use none at all.
Reply #33 on:
November 17, 2009, 19:00 »
Watch for the dropped top.
Reply #34 on:
November 17, 2009, 19:40 »
Been there, done that using all wholemeal flour or an inferior brand. Haven't had a dropped top for a long time now but I will report back when I make my next loaf in a week's time.
GillE
Never totally serious
Reply #35 on:
November 17, 2009, 19:49 »
Quote from: Clive on November 17, 2009, 19:40
Haven't had a dropped top for a long time now ...
You're not dropping little blue lozenge shaped pills into the dough mix, Clive?
(Schopenhauer,
Die Kunst Recht zu Behalten
Reply #36 on:
November 17, 2009, 20:06 »
It could be a cheaper alternative to yeast Gill! I've read that the pills are very effective in reviving cut flowers too.
Reply #37 on:
November 17, 2009, 21:17 »
Can't you spare one to try it, Clive?
Reply #38 on:
November 17, 2009, 21:25 »
Certainly not Simon!
Reply #39 on:
November 17, 2009, 21:26 »
Reply #40 on:
November 23, 2009, 13:17 »
I've made a completely salt free loaf of bread although I notice that the Marvel I add to supply calcium contains salt anyway. The bread rose more or less the same as before but the bread didn't break through the top of the crust in the manner I like to see. Of course this is merely aesthetically pleasing and makes no difference to the taste. But I'm not quite certain that the consistency is as good. The crust isn't quite so crusty and the bread has a slightly rubbery feel on the outside. I think I will revert to adding a pinch of salt next time I bake!
Reply #41 on:
November 23, 2009, 13:26 »
That's what we've found, Clive, it needs some salt, the trick is to minimise how much. Adding gluten helps.
Food & Drink
