Author Topic: Vista & IE7 or IE8  (Read 2178 times)
Offline maria9547
Vista & IE7 or IE8
« on: November 19, 2009, 15:51 »
I'm having problems with Internet Explorer.  No matter what version I run, it usually slows down when browsing to the point where I get (Not Responding) and the program has to restart.  :-\  Its frustration because I do like IE, but I'm lucky to have Mozilla too.
Any tips on how to fix the IE problem?   Thanks.
Re: Vista & IE7 or IE8
« Reply #1 on: November 19, 2009, 17:10 »
What version of Windows, Maria, how much RAM, free hard disk space and what processor do you have. What AV software do you use? If you open task manager (Ctrl-Alt-Del), how many processes are running and how much CPU time are they taking?
Offline Den
« Reply #2 on: November 19, 2009, 17:37 »
Hi Maria, I had the same problem and cured it by uninstalling IE8 completely and then re-installed it. I downloaded and saved it on my desktop before I uninstalled.  ::)
Offline maria9547
« Reply #3 on: November 20, 2009, 00:49 »
Windows Vista Home Premium 32 bit
Ram 3,00 GB
206GB free of 286GB
Processer - Intel(R)Core(TM) 2 Duo CPU T5550@1.83GHz  1.83GHz
processes running 78 (and I don't even know what most of them are for)
cpu time = 5% usage
Microsoft Security Essentials for AV software
(I don't know how to copy the list of processes from the task manager)
Thanks.
« Reply #4 on: November 20, 2009, 07:35 »
All you can do is post a screenshot, Maria.  :)
« Reply #5 on: November 20, 2009, 09:19 »
That would be useful, Maria. 78 processes is way more than I have on any of my machines.
Offline maria9547
« Reply #6 on: November 20, 2009, 23:40 »
 ???  How do I post a screenshot?  Thanks.
« Reply #7 on: November 21, 2009, 00:07 »
Actually, what might be easier is if you run a program called HijackThis.  This program will list all of your running processes, and allow you to create a log file, which you can then copy and paste on here.  We'll have a look at it, and see if we can see anything that shouldn't be there.
Offline maria9547
« Reply #8 on: November 21, 2009, 21:00 »
ok - here we go:
Logfile of HijackThis v1.99.1
Scan saved at 12:57:16 PM, on 11/21/2009
Platform: Unknown Windows (WinNT 6.00.1906 SP2)
MSIE: Internet Explorer v7.00 (7.00.6002.18005)
Running processes:
C:\Windows\system32\taskeng.exe
C:\Windows\Explorer.EXE
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe
C:\Program Files\Realtek\Audio\HDA\RtHDVCpl.exe
C:\Program Files\Intel\Intel Matrix Storage Manager\IAAnotif.exe
C:\Program Files\HP\QuickPlay\QPService.exe
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QLBCTRL.exe
C:\Program Files\Hewlett-Packard\HP QuickTouch\HPKBDAPP.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe
C:\Program Files\Microsoft Security Essentials\msseces.exe
C:\Program Files\BillP Studios\WinPatrol\WinPatrol.exe
C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
C:\WINDOWS\System32\rundll32.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Program Files\Hewlett-Packard\Shared\HpqToaster.exe
C:\Windows\system32\wbem\unsecapp.exe
C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\Windows\system32\Dwm.exe
C:\Program Files\Internet Explorer\ieuser.exe
C:\Windows\system32\Macromed\Flash\FlashUtil10c.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\PROGRA~1\WINZIP\winzip32.exe
C:\Users\Maria\AppData\Local\Temp\wz8316\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=en_us&c=81&bd=Pavilion&pf=laptop
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O1 - Hosts: ::1 localhost
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: NCO 2.0 IE BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - (no file)
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: HP Print Clips - {FFFFFFFF-FF12-44C5-91EC-068E3AA1B2D7} - c:\Program Files\HP\Smart Web Printing\hpswp_framework.dll
O3 - Toolbar: (no name) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - (no file)
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [SMSERIAL] C:\Program Files\Motorola\SMSERIAL\sm56hlpr.exe
O4 - HKLM\..\Run: [RtHDVCpl] C:\Program Files\Realtek\Audio\HDA\RtHDVCpl.exe
O4 - HKLM\..\Run: [IAAnotif] C:\Program Files\Intel\Intel Matrix Storage Manager\iaanotif.exe
O4 - HKLM\..\Run: [QPService] "C:\Program Files\HP\QuickPlay\QPService.exe"
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [OnScreenDisplay] C:\Program Files\Hewlett-Packard\HP QuickTouch\HPKBDAPP.exe
O4 - HKLM\..\Run: [UCam_Menu] "C:\Program Files\CyberLink\YouCam\MUITransfer\MUIStartMenu.exe" "C:\Program Files\CyberLink\YouCam" update "Software\CyberLink\YouCam\1.0"
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [hpWirelessAssistant] C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
O4 - HKLM\..\Run: [WAWifiMessage] C:\Program Files\Hewlett-Packard\HP Wireless Assistant\WiFiMsg.exe
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [MSSE] "c:\Program Files\Microsoft Security Essentials\msseces.exe" -hide
O4 - HKLM\..\Run: [WinPatrol] C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe -expressboot
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files\HP\Digital Imaging\bin\hpqSRMon.exe
O4 - HKCU\..\Run: [LightScribe Control Panel] C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe -hidden
O4 - HKCU\..\Run: [ISUSPM Startup] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -startup
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: (no name) - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: HP Smart Select - {58ECB495-38F0-49cb-A538-10282ABF65E7} - c:\Program Files\HP\Smart Web Printing\hpswp_extensions.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\windows\system32\nlaapi.dll
O10 - Unknown file in Winsock LSP: c:\windows\system32\napinsp.dll
O10 - Unknown file in Winsock LSP: c:\program files\bonjour\mdnsnsp.dll
O11 - Options group: [INTERNATIONAL] International*
O13 - Gopher Prefix:
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cab
O16 - DPF: {A1662FB6-39BE-41BB-ACDC-0448FB1B5817} (Photo Upload Plugin Class) - http://www.cvsphoto.com/upload/activex/v3_0_0_5/PhotoCenter_ActiveX_Control.cab
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O16 - DPF: {EFD1E13D-1CB3-4545-B754-CA410FE7734F} (Photo Upload Plugin Class) - http://www.cvsphoto.com/upload/activex/v3_0_0_2/PhotoCenter_ActiveX_Control.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{FBA584B9-B150-41D1-8F0B-F35C8A420C0A}: NameServer = 192.168.1.254,4.2.2.3
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O18 - Protocol: wlmailhtml - {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll
O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Com4Qlb - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\Com4Qlb.exe
O23 - Service: @%SystemRoot%\ehome\ehstart.dll,-101 (ehstart) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: @gpapi.dll,-112 (gpsvc) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: HP Health Check Service - Hewlett-Packard - c:\Program Files\Hewlett-Packard\HP Health Check\hphc_service.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: Intel(R) Matrix Storage Event Monitor (IAANTMON) - Intel Corporation - C:\Program Files\Intel\Intel Matrix Storage Manager\IAANTMon.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\Windows\system32\nvvsvc.exe
O23 - Service: QuickPlay Background Capture Service (QBCS) (QPCapSvc) - Unknown owner - C:\Program Files\HP\QuickPlay\Kernel\TV\QPCapSvc.exe
O23 - Service: QuickPlay Task Scheduler (QTS) (QPSched) - Unknown owner - C:\Program Files\HP\QuickPlay\Kernel\TV\QPSched.exe
O23 - Service: @%SystemRoot%\system32\qwave.dll,-1 (QWAVE) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
O23 - Service: @%SystemRoot%\system32\seclogon.dll,-7001 (seclogon) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - %ProgramFiles%\Windows Media Player\wmpnetwk.exe (file missing)
« Reply #9 on: November 21, 2009, 22:14 »
I'm no expert on these, but I can't see anything obvious, Maria.  Did you say that you can use Mozilla without any problems?  Do you actually use Skype and do you need the toolbar?  I don't use it myself, so I don't know if it's essential, but any add-ons like this can cause problems.
As you have Microsoft Security Essentials, it might be worth disabling WinPatrol, just as a test, in case they are conflicting.  Sorry that's nothing definite, it's just a matter of elimination, really.
Offline maria9547
« Reply #10 on: November 23, 2009, 16:23 »
No, I have to admit that I don't use Skype or the toolbar.   I'll try disabling WinPatrol and see what happens.   I don't have problems with Mozilla's Firefox, but I'm so used to IE that I use that most the time.
Thanks for looking it over for me.
« Reply #11 on: November 23, 2009, 16:32 »
Basically, I would disable, or preferably, uninstall anything you don't use, especially toolbars, and see if that helps.  Otherwise, try to get used to Mozilla, as it's a much better browser anyway.  :)
Offline maria9547
« Reply #12 on: November 23, 2009, 16:36 »
sounds good. Thanks.
