Author Topic: Almost full c:drive  (Read 2008 times)
Offline MikeDavies
Almost full c:drive
« on: November 26, 2009, 14:20 »
Hi, hope someone can help.
My daughter has an Acer 5315 laptop using Vista basic.
It has two internal drives c: 40Gb and d: also 40 Gb.
The C: drive is says its almost full but going thru the folders/files I can only find approx 24Gb including 16Gb for Vista. I have set it to show hidden files.
Any ideas what is clogging up this drive?
Many thanks in advance
Mike
Re: Almost full c:drive
« Reply #1 on: November 26, 2009, 14:32 »
Hi Mike,
Someone will be along to help soon, but in the meantime, have you cleared out the temp files and recycle bin?
Offline MikeDavies
« Reply #2 on: November 26, 2009, 14:46 »
Yes, and carried out a disc cleanup etc.
« Reply #3 on: November 26, 2009, 15:04 »
There's a handy free little program called SequoiaView which will give you a pictorial representation of just what is on the HDD.
« Reply #4 on: November 26, 2009, 15:31 »
Check for memory dumps, hyberfil.sis and the size of the page file, Mike.
Offline MikeDavies
« Reply #5 on: November 26, 2009, 16:07 »
Thanks everyone for your inputs, I'll try them out and let you know how I get on
Mike
Offline Baz
« Reply #6 on: November 26, 2009, 18:21 »
will the drives just be ONE drive with TWO partitions. My wifes is like that.Vista is on C I think and all data on D
« Reply #7 on: November 26, 2009, 18:32 »
I'd bet on it, Baz.
Offline MikeDavies
« Reply #8 on: November 27, 2009, 10:25 »
Thanks everyone, managed to retrieve approx 7 Gb with your suggestions. Very useful programme that SequiaView!
thanks once again
Mike
« Reply #9 on: November 27, 2009, 10:26 »
Glad you're sorted, Mike. Windows does like to eat hard drives. ;)
